Old 10-19-2016, 13:15   #1 (permalink)
maanarman's Avatar
Member: 686395
Sonork: 100.1608345
Thanks Meter: 3,822
encryption unsuccessful after format please help
Hi
phone Ask password on factory data reset my first step backup firmware
here is logs
Wait for phone...
Phone found! [ 36 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6575
BB_CPU_NME : [MediaTek] MT6575|MT6577_S00
BB_CPU_EXT : 0xCB00 , 0x8A00 , 0xE201
Processing BROM stage
i2c Init : 00000000
SpeedSet : 0000
VChrgSet : 0x28 , BatStat : 0x02
WD Disable stat : 0x0000
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer   : 0x00FF
BLVersion : 0x0001
BootLdrSS : NORMAL with SPRELOADER
Processing DA stage
DA Select done, will use MTK_AllInOne_DA_v5.1612.01.01
Sending and initialize DA ...
Running DA ver.3.2 on BBID : 0x84
Initialize Memory ...
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , HYNIX
[eMMC] : FLASH_CID : 90014A2058494E594811B45DEAC14F1B
[eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000
[eMMC] : FLASH_LEN : 0x00000000E7000000
[eMMC] : FLASH_UCP : 3696 MiB [eMMC 4 GiB]
DEV RID    : 16587AB69EE5501DEB93CA7EF6D96080
INT RAM    : 0x00020000
EXT RAM    : 0x20000000
BOOT TYPE  : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Reading Flash Content now ...
Brand     : samsung
ProdName  : GT-i9060I
ProdModel : SM-I9060I
Device    : grandneove3g
AndroidVer: 4.4.4
MTKxCPU   : MT6575
[Read Ok] : preloader_mbk75_twn_cu_jb.bin
[Read Ok] : DSP_BL
[Read Ok] : MBR
[Read Ok] : EBR1
[Read Ok] : lk.bin
[Read Ok] : boot.img
[Read Ok] : recovery.img
[Read Ok] : secro.img
[Read Ok] : logo.bin
[Read Ok] : EBR2
[Read Ok] : system.img
[Make Ok] : cache.img
[Make Ok] : userdata.img
[ScatCFG] : MT6575 / V1.0.0 / mbk75_twn_cu_jb / EMMC
Android Info saved
MAUI Meta DB saved
HWConfig Info saved
FW Size : 571 MiB
Scatter saved to : C:\Users\maanarman\Desktop\Cmm\MT6575__samsung__SM-I9060I__grandneove3g__4.4.4__\
All done!
Done!
Elapsed: 00:04:08
Reconnect Power/Cable!
i try to format cm2 after format give error encryption unsuccessful
here is format logs
Wait for phone...
Phone found! [ 36 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6575
i2c Init : 00000000
SpeedSet : 0000
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Clear RDP
Clear Ok!
Done!
Elapsed: 00:00:09
i also try to write backup but i face error in flashing
here is flashing logs
Scatter Load Ok , BaseBand : MT6575 , Project : MTK6575 , Storage : eMMC
Files found : 12 , Set to Flash : 11
Created by Infinity-Box (c) Chinese Miracle II (c) 2016
Device Brand   : samsung
Device Model   : grandneove3g
Device CPU     : MT6575
Device IntName : GT-i9060I
Device Version : 4.4.4
Device Compile : 3/3/2016 4:04:28 PM
Device ExtInfo : SM-I9060I
Ready to Flash!
Start  at : [10/18/2016 / 3:49:08 PM]
Operation : Flash [ v1.47 ]
======= Flash
Wait for phone...
Phone found! [ 36 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6575
i2c Init : 00000000
SpeedSet : 0000
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6575 , Project : MTK6575 , Storage : eMMC
Setting : AFF verify :  Enabled
Setting : HW verify :  Enabled
BL : Check HW compatibility
BL : Check eMMC compatibility
BL : Old Dedvice , skip BatteryLevel check
BL : Flash Pre-Erase
Total blocks to Erase : 2
Erase : 0x0000000000600000-0x0000000000060000
Erase : 0x0000000000D80000-0x00000000E4280000
Flash Pre-Erase Done, time used : 00:00:07
SecCfg Passed , 1799
BMT remark not need. Will skip
Sending Preloader ...
Use : preloader_mbk75_twn_cu_jb.bin
Preloader Init Failed! Looks like HW error or incompatible image
ErrCode :
Operation Failed
Elapsed: 00:00:18
emmc test logs
Wait for phone...
Phone found! [ 36 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6575
i2c Init : 00000000
SpeedSet : 0000
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Processing Miscellaneous test
MSC : BatteryLevel : Unknown ( Not supported (EmbdedBattery) or Without battery )
[Processing] FlashMemory Read-Write test
[eMMC] : [HYNIX] , HYNIX , 0xE7000000 , 3696 MiB
[eMMC] : CID : 90014A2058494E594811B45DEAC14F1B
[eMMC] : MODE : SQ-WR
[PASSED] : eMMC RW Check #1 Ok!
[eMMC] : MODE : RA-WR
[PASSED] : eMMC RW Check #2 Ok!
[eMMC RO CHECK] : eMMC Ok! READ-WRITE Passed!
[Processing] RAM Read-Write test
[DRAM] : 0x20000000 , 512 MiB
[DRAM] : ADDRESS BUS test
[PASSED] : Bus Count : 0x1C
[DRAM] : DATA BUS test
[PASSED] : Bus Count : 0x1F
[DRAM] : PATTERN test
[PASSED] : PATTERN Ok
[DRAM] : INCDEC test
[PASSED] : INCDEC Ok
All Done!
Done!
please help me Cm2
Old 10-19-2016, 13:31   #2 (permalink)
PASSIONATE_BOYS's Avatar
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,361
Hello,
Do Repair Ext Data.
Br.
Infinity Box Support Team.
Old 10-19-2016, 13:51   #3 (permalink)
maanarman's Avatar
Member: 686395
Sonork: 100.1608345
Thanks Meter: 3,822
Originally Posted by PASSIONATE_BOYS View Post
Hello,
Do Repair Ext Data.
Br.
Yes Sir here is logs my bad luck still same condition
Wait for phone...
Phone found! [ 36 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6575
i2c Init : 00000000
SpeedSet : 0000
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Refill : Cache
Refill Ok!
Refill : UserData
Refill Ok!
Done!
Elapsed: 00:00:41
Old 10-19-2016, 14:19   #4 (permalink)
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,361
Use latest version, not so old version.
Br.
Old 10-19-2016, 14:37   #5 (permalink)
maanarman's Avatar
Member: 686395
Sonork: 100.1608345
Thanks Meter: 3,822
Br.
My yearly activation expire
Can i solve this problem With Cm2 ???
Old 10-19-2016, 17:40   #6 (permalink)
Kirumira's Avatar
Member: 96478
Sonork: 100.1674604
Thanks Meter: 1,420
Ofcourse,Yes
infinitysupport; =MT6573 and MT6575/MT6577 support has been broken. Fixed
MTK.v158
Old 10-19-2016, 19:11   #7 (permalink)
maanarman's Avatar
Member: 686395
Sonork: 100.1608345
Thanks Meter: 3,822
please help me team i need repair this mobile
Old 10-19-2016, 19:53   #8 (permalink)
princesaddam's Avatar
Member: 1010626
Sonork: using fb
Thanks Meter: 735
Hello,
Select second option in format and do format and check once
Sent from my S_plus using Tapatalk
Old 10-20-2016, 08:59   #9 (permalink)
Member: 2461703
I have highscreen boost 2 se ... Encryption Unsuccessful,,, Have solution ? Help? Thanks!!
Old 10-20-2016, 15:50   #10 (permalink)
maanarman's Avatar
Member: 686395
Sonork: 100.1608345
Thanks Meter: 3,822
No Any Reply From Team Please How TO Solve This Problem
Old 10-20-2016, 16:28   #11 (permalink)
syed tuqeer's Avatar
Member: 654997
Sonork: 1613804(Don't Spam Plz)
Thanks Meter: 4,073
Hello,
find Original / working Rom and flash phone
or disable HW Check option (at own risk) and flash backup
post result/logs.....
Old 10-20-2016, 21:30   #12 (permalink)
maanarman's Avatar
Member: 686395
Sonork: 100.1608345
Thanks Meter: 3,822
one same working phone also in my hand i try both option
please JayDi sir help me if possible
Old 10-21-2016, 07:20   #13 (permalink)
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,361
Read NVRAM, full erase and flash again with working firmware.
BTW Repair Ext Data is enough to repair Encryption Unsuccessful problem.
Br.
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post:
Page generated in 0.26529 seconds with 8 queries
