Old 09-27-2007, 11:01   #1 (permalink)
kasim's Avatar
Member: 107448
Thanks Meter: 29
NEEDED Sands A203 pinouts
Hello brother !
I am looking for Sands A203 pinouts ! Its connector is same As samsung E900,D800,D900.....ect ) 20 pin !
- 1+Vpp
- 2,4,14,18 GND
I nead TX and RX
pins please ! It's urgent !
Old 09-27-2007, 13:37   #2 (permalink)
MUNEEB_AKHTAR_RAZA's Avatar
Member: 152244
Sonork: 100.1591179
Thanks Meter: 162
R u mad or what??....U requested 3 times for same.....ANd even after getting answer u make a new thread why?ANyways...
Here is what i found!
3, 7, 19 - GND
20 - VCC
9 - RX
13 - TX
Note:always try to reverse tx and rx when pinouts not working or count from other side!
If this still not help.....Then read this from infinity team!
How to find pinout for unknown model
Please, follow instruction exactly like described below
In most cases you need to know Gnd, Rx, Tx pins for flash/unlock operations. What do do if you don't have cable or you have new phone model:
1. find Gnd pin (it's required step, you can't continue until you will know Gnd pin location)
2. find Charge pins (it's optional step, just to save your time during future research)
3. find +Battery pins (it's optional step, just to save your time during future research)
4. connect cable Gnd to phone Gnd
5. try to connect cable Rx/Tx wires to all phone contacts one by one (except Gnd, Charge, +Battery pins) and try to read flash from phone
6. if flash read procedure can start this means that pinout found Ok and you can make other operations
Note about "Chinese models": a lot of different phones with the same name exist on market (as well as many different name phones with the same pinouts), so, if you see in our "cable selector" wrong pinout for "Chinese models" it's good idea to find correct pinout according to above instruction and send new pinout information with full text from phone back label to [email protected]
MUNEEB AKHTAR RAZA
need SANDS A8 Pinout chaparal Chinese Cocktail 2 02-09-2009 09:39
sands a203 pinout here sonumobilewala Infinity-Box 3 07-28-2008 15:30
Jack please help. need Sands A203 flash file. prolink1628 SpiderMan 2 05-14-2008 09:07
need pinout for sands A203 ashok_kumar459 Infinity-Box 3 09-24-2007 06:06
sands a203 pinout????????? edy2002gha Infinity-Box 3 09-12-2007 21:16
Page generated in 0.22052 seconds with 9 queries
