Old 04-27-2016, 12:59   #1 (permalink)
khanzada606's Avatar
Member: 2455344
Sonork: Ask me
Thanks Meter: 420
ErrCode : 0xAFC
Qtab 400
Stuck On Logo
tried tested Flash file and more flash files all then it
Phone found! [ 30 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BB_CPU_NME : [MediaTek] MT6582_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
BootLdrSS : NORMAL with SPRELOADER
Processing DA stage
DA Select done, will use MTK_AllInOne_DA_v5.1612.01.01
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x87
NAND Flash : NOT INSTALLED
eMMC Flash : 15010038574D423352015ED145C74123
Initialize Memory ...
eMMC FlashIC initialized
[eMMC] : FLASH_INF : [SAMSUNG] , R3BMW
[eMMC] : FLASH_CID : 15010038574D423352015ED145C74123
[eMMC] : FLASH_LEN : 0x00000001D2000000
[eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB]
DEV RID : 86F829F96A2ADCBDD1F5E6D7D0959CF1
INT RAM : 0x00020000
EXT RAM : 0x40000000
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6582 , Project : reallytek82_tb_jb5 , Storage : EMMC
Setting : AFF verify : Enabled
Setting : HW verify : Enabled
BL : Check HW compatibility
BL : Check eMMC compatibility
BL : Only one records found, and determined as universal
BL : BatteryLevel : 3696 mV
BL : BatteryLevel Ok
BL : Flash Pre-Erase
Total blocks to Erase : 2
Erase : 0x0000000001400000-0x0000000000100000
Erase : 0x0000000003100000-0x00000001CE280000
Flash Pre-Erase Done, time used : 00:00:06
SecCfg Passed , 1799
BMT remark not need. Will skip
Sending Preloader ...
Use : preloader_reallytek82_tb_jb5.bin
Preloader Sent , Init passed
PartCount : 0014
Update PMT by user request
Repartition Done!
Processing : Flash Write
Flash now : MBR
Image Flash Ok
Flash now : EBR1
Image Flash Ok
Flash now : UBOOT
Image Flash Ok
Flash now : BOOTIMG
Image Flash Ok
Flash now : RECOVERY
Image Flash Ok
Flash now : SEC_RO
Image Flash Ok
Flash now : LOGO
Image Flash Ok
Flash now : EBR2
Image Flash Ok
Flash now : ANDROID
Image Flash Ok
Flash now : CACHE
Image Flash Ok
Flash now : USRDATA
Image Flash Ok
Flash Write Done, time used : 00:02:15
Processing : Verify
Verify Passed : MBR
Verify Passed : EBR1
Verify Error! Something went wrong!
ErrCode : 0xAFC9
Operation Failed
Elapsed: 00:02:52
Reconnect Power/Cable!
Old 04-27-2016, 13:09   #2 (permalink)
PASSIONATE_BOYS's Avatar
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,361
Hello,
Check eMMC for RO under Repair-Extra tab.
Br.
Infinity Box Support Team.
Old 04-28-2016, 13:39   #3 (permalink)
Member: 2455344
Sonork: Ask me
Thanks Meter: 420
[Processing] FlashMemory Read-Write test
[eMMC] : [SAMSUNG] , R3BMW , 0x1D2000000 , 7456 MiB
[eMMC] : CID : 15010038574D423352015ED145C74123
[eMMC] : MODE : SQ-WR
[FAILED : READONLY] : eMMC state seems as READ-ONLY !!!!
Operation Failed
Elapsed: 00:00:40
Old 04-28-2016, 14:15   #4 (permalink)
Kirumira's Avatar
Member: 96478
Sonork: 100.1674604
Thanks Meter: 1,420
Its readonly,repair emmc or replace.
The Following User Says Thank You to Kirumira For This Useful Post:
Old 04-28-2016, 19:36   #5 (permalink)
Member: 2455344
Sonork: Ask me
Thanks Meter: 420
Can Rehot or reballing fix this?
Old 04-29-2016, 07:39   #6 (permalink)
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,361
No, only change is permanent solution. Re-programmig it via some other device will make it working for temporary period.
Br.
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post:
Page generated in 0.16196 seconds with 8 queries
