09-16-2011, 12:53 | #1 (permalink) |
Freak Poster Join Date: Apr 2009 Location: india
Member: 1019173 Status: Offline Sonork: crown mobile Thanks Meter: 37 | error# 0000FFFF i am flashing micromax x260 show this error - please help COM41 [VCP1] selected module v3.62 Device: Micromax-X260 Checking data, wait... advanced flash detection enabled Action: write flash write: Firmware Micromax-X260_TBG111212_6492_PCB01_GPRS_MT6223P_S00[1].111212_6492_V0710_2010-03-09_En_Hi.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:BC1C:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98000300000001:2BEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (05) TCL-ID is absent ==================== New firmware found (v.3.62, database date: 01.10.2010): TBG111212_6492_PCB01_GPRS_MT6223P_S00.111212_6492_ V0710.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare – Secure Data Logistics or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished rom info ver: 05 sw version: TBG111212_6492_PCB01_GPRS_MT6223P_S00.111212_6492_ V0710.BIN project-id: 111212_6492_V0710, 00000000 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: [standard] type (05) TCL-ID is absent ffs/eeprom address assigned: 00E00000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... sec info (fast) detection... searching sec info#1... . search sec info#1 finished usb bootloader (file) is absent startup code area #1 check... done Area: Firmware flash: 98000300000001:2BEA0000000000 Write: Firmware error: error# 0000FFFF error: flash write error: 004B6000:00002000 error: write operation failed Write Fail Finished, time used: 10 min 51 sec Remove/Install battery now ! |
09-16-2011, 13:46 | #2 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | First of all use latest module for best result, don't use so old modules. Secondly what was condition of the phone when you received it? This could be due to hardware (partially damaged flash chip) problem. Wr. |
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post: |
09-17-2011, 12:13 | #3 (permalink) | |
Member: 1043909 Status: Offline Thanks Meter: 60,861 | Quote:
@mohd.asim any results with latest software ? | |
09-17-2011, 12:18 | #4 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,531 | hello! which box do you use as interface? this error usually appear because of bad Prolific drivers. |
09-20-2011, 19:13 | #8 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,531 | hello! this was prolific drivers problem. we have good drivers on support site. just replace them and you will never see this error again |
help: CMT Flash ID: 0000FFFF | topline | J.A.F. By Jafsupport.com | 0 | 02-28-2008 17:49 |
