07-24-2017, 14:35 | #1 (permalink) |
No Life Poster Join Date: Sep 2006 Age: 45
Member: 348590 Status: Offline Sonork: 100.108198 Thanks Meter: 200 | Bgh positivo y100 not frp ----- > Phone/Tablet : 1. Power Off device 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable! Press 'POWER_ON' button for a few second! ----- > IoT/Box : 1. Reset device power 2. PRESS and HOLD 'RESET' KEY! 3. Insert OTG/USB cable! Press 'POWER_ON' button for a few second! Wait for device ... Device Connected! Interface test : Passed Device mode : Protected! [ LOADER PROTECTED ] Machine : RK312X Device : RK312X ExtInfo : 6.0.0 SoC CPU : 312A SoC PDT : 2014 SoC SWN : 0730 SoC REV : V100 Flash CSx : 0x00 Flash Type : ADDE94DA74 [ NAND ] Flash Vend : HYNIX Flash Size : 0x000000020A800000 ( 8,16 GiB ) Flash Info : 2097152/8192/32/40/1 Connect Ok! Remove FRP 0 ... FRP removed! Wiping UserData ... Wipe DATA Ok! Done! Elapsed: 00:00:57 Proccess is OK. Tablet blocked google account |
07-24-2017, 14:52 | #2 (permalink) | |
No Life Poster Join Date: Jan 2013 Location: gsmhosting Age: 29
Member: 1876736 Status: Offline Thanks Meter: 735 | Quote:
PROTECTED mode limitations: WRITE PROTECTED ( you can ONLY read fw, patternlock, identify ) so not supported at the moment | |
07-24-2017, 18:50 | #3 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Solution has been finished. But for now is a bit complicated. Making 1-clock solution. Can take some time, but will be soon. |
