06-26-2009, 23:52 | #1 (permalink) |
No Life Poster Join Date: Nov 2007 Location: Central America
Member: 628110 Status: Offline Thanks Meter: 87 | [ERROR] Alcatel s319a not imei repair in MMODULE v2.78 Code: COM12 [VCP0] selected module v2.78 Device: Alcatel-S319X, S319A Checking data, wait... advanced flash detection enabled Action: "repair imei" new imei: 011455001011249 Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:2240:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 98004900000002:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud ... 460800 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 detection finished identification#1 protocol ver: 05 ver. sw 1: JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_07A_W07_36_SP1_V20.BIN ver. sw 2: MAUI.07A.W07.36.SP1.V20, 00000000 ffs offset/size: 00C00000/00400000 detect device identification#2... detection phase #1... detect device identification#2 finished sim-lock status: enabled security area (code #3, part #2) calculation... customization: CH16PB30 customization area adjusted: CH16PB30 done flash: 98004900000002:2AEA0000000000 flash: 98004900000002:2AEA0000000000 Write: security area (code #3, part #2) security area (code #3, part #2) calculation done security area (code #3, part #1) calculation... use default security area (code #3, part #1) pattern ..................security area (code #3, part #1) detecting size... security area (code #3, part #1) detecting parameters... security area (code #3, part #1) encoding... done flash: 98004900000002:2AEA0000000000 flash: 98004900000002:2AEA0000000000 Write: security area (code #3, part #1) security area (code #3, part #1) calculation done Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... flash: 98004900000002:2AEA0000000000 Backup required data Done Patch required data ... ................................................ ................................................ ................................................ ......................... original data found, method-B area footer mismatch, unknown firmware, read flash and send to support Patch required data Fail file saved: C:\Archivos de programa\InfinityBox\MModule\backup_security\Alcatel-S319X,S319A_JRD23_07A_PCB01_GPRS_MT6223_S00.MAUI_07A_W07_36_SP1_V20__system_log__FFFFFFFF_20090626-164355.B0X.bin Finished, time used: 321 sec Remove/Install battery now ! |
The Following User Says Thank You to WeBoXGT For This Useful Post: |
samsung i900 boot repair and radio not signal repair in colombia | j_gerdts | QUALCOMM Models (3G) | 0 | 01-26-2010 20:37 |
how in imei repair with ChineseMiracle v2.66 | neo.com | Infinity-Box | 3 | 11-04-2008 23:06 |
12 Aug 2008: Alcatel-OT-C7xx, OT-C8xx, OT-V7xx, OT-S5xx imei repair in test etc. | InfinitySupport | Infinity-Box | 35 | 09-28-2008 20:40 |
Itīs posible IMEI REPAIR in Qtek S200?. Help ĄĄ | Grupo MovilFree | HTC & PDA WM( With Touchscreen) | 2 | 02-04-2007 16:50 |
Itīs Posible IMEI REPAIR in Alcatel 0.T 535?ŋ?ŋ | Grupo MovilFree | BF, BG, TH, BHx Series | 1 | 07-21-2004 00:09 |
