11-21-2009, 14:12 | #1 (permalink) |
Freak Poster Join Date: Jan 2009
Member: 950629 Status: Offline Thanks Meter: 105 | error: can not finalize test mode I try also with 1. set format to complete mode. 2. boot packet size set to stable. But still same. this is the log. COM4 [VCP0] selected module v2.97 Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:3703:000C status: FF Connecting at 19200, wait... error: can not finalize test mode repeat operation and HOLD phone "Power" button long time ! error: operation failed ! Finished, time used: 35 sec Remove/Install battery now ! |
11-21-2009, 19:41 | #3 (permalink) | |
Member: 130995 Status: Offline Thanks Meter: 35,229 | Quote:
Please, DO NOT lie here ! It CAN NOT be the same error if you have tried to make format in "complete" mode ! You must be honest, in other case nobody can help you ! Now, make all procedures again and follow advices given by software exactly and then POST HERE YOUR RESULTS WITHOUT LIE ! | |
11-22-2009, 11:21 | #5 (permalink) |
Member: 950629 Status: Offline Thanks Meter: 105 | @ InfinitySupport Hi.. I do not lie. I want fix my phone only. I mean " I cant fix my phone yet also using Complete mode format" by "Still same" Am i wrong? Thank you for understanding. ----------------------------------------------------------------------------------------------------------- This is the log using safe mode format. COM4 [VCP0] selected module v2.97 Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:3703:000C status: FF Connecting at 19200, wait... error: can not finalize test mode repeat operation and HOLD phone "Power" button long time ! error: operation failed ! Finished, time used: 83 sec Remove/Install battery now ! I repeat the safe format and hold power button untill operation end but it say "error: can not finalize test mode" again. This is the log using complete mode format COM4 [VCP0] selected module v2.97 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: "format ffs" ffs/eeprom backup enabled, it may takes several minutes ! Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:3703:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba T 16Mb detecting chip #01 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba T 16Mb detecting chip #02 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba T 16Mb detecting chip #03 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba T 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 460800 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba T 16Mb detecting chip #01 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba T 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is absent ==================== New firmware detected (v.2.97, database date: 08.11.2009): SW_2801_EN_PCB01_GPRS_MT6225_S00.SW_2801_EN_V009_M 10_RIXIN.BIN This firmware is missing in support area. If this phone is good and working: - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished rom info protocol ver: 04 ver. sw 1: SW_2801_EN_PCB01_GPRS_MT6225_S00.SW_2801_EN_V009_M 10_RIXIN.BIN ver. sw 2: SW_2801_EN_V009_M10_RIXIN, 00000000 address offset: 00000000 ffs offset/size: 00E00000/001F8000 detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 flash: 98000300000001:18E59F00000000 checking area [00000000]: 00000000-00FFFFFF... ffs/eeprom found near: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: SW_2801_EN_PCB01_GPRS_MT6225_S00.SW_2801_EN_V009_M 10_RIXIN__ffs... file saved: G:\Program Files\InfinityBox\ChineseMiracle\SW_2801_EN_PCB01_ GPRS_MT6225_S00.SW_2801_EN_V009_M10_RIXIN__ffs_200 91122-184138.B0E.bin flash: 98000300000001:18E59F00000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Write Done Finalization ... ffs formatting... flash: 98000300000001:18E59F00000000 error: wrong erase first sector at 0x00E00000 Finalization Fail Finished, time used: 87 sec Remove/Install battery now ! This is phone detail COM4 [VCP0] selected module v2.97 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: read/check detailed information Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:3703:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba T 16Mb detecting chip #01 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba T 16Mb detecting chip #02 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba T 16Mb detecting chip #03 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba T 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 460800 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba T 16Mb detecting chip #01 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba T 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is absent ==================== New firmware detected (v.2.97, database date: 08.11.2009): SW_2801_EN_PCB01_GPRS_MT6225_S00.SW_2801_EN_V009_M 10_RIXIN.BIN This firmware is missing in support area. If this phone is good and working: - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished rom info protocol ver: 04 ver. sw 1: SW_2801_EN_PCB01_GPRS_MT6225_S00.SW_2801_EN_V009_M 10_RIXIN.BIN ver. sw 2: SW_2801_EN_V009_M10_RIXIN, 00000000 address offset: 00000000 ffs offset/size: 00E00000/001F8000 detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 flash: 98000300000001:18E59F00000000 checking area [00000000]: 00000000-00FFFFFF... ffs/eeprom found near: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF detecting ffs/eeprom structure pass 1... ........................ detect standard ffs/eeprom location pass #1... .................................................. ... detect standard ffs/eeprom offset pass #1... ffs/eeprom record offset detected detect standard ffs/eeprom data... ffs/eeprom record size detected ffs/eeprom layout detection complete ffs/eeprom detected ok: element #1 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Finished, time used: 45 sec Remove/Install battery now ! @ InfinityHelp I use Pin Finder interface(APF box plus) with L10C cable. Thank you two for quick help..! |
11-22-2009, 11:53 | #6 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,229 | @mswmkm It was not "the same" with "complete format", so please, do not write "the same" if in fact it was not "the same". what to do: use latest ChineseMiracle 3.00 and make "complete format" again |
11-23-2009, 16:37 | #8 (permalink) |
Member: 950629 Status: Offline Thanks Meter: 105 | I didn't have a chance to use version 3 and see the result. My customer(the H1i phone owner) took back his phone. Definitely i will let you know about the result, as soon as i got this model again. Thank you two for again who are the great helpers on this forum. |
n88 error: can not finalize test mode | micmac | Infinity-Box | 5 | 03-03-2010 23:01 |
error: can not finalize test mode | sidramobilecare | Infinity-Box | 3 | 01-27-2010 21:20 |
how can i flash motorolla phone which can not enter TEST MODE? | kwasasco | Motorola P2k | 1 | 07-12-2008 08:50 |
Z310 can not Leaving test mode!!!!! | kifah | Universalbox | 4 | 09-06-2007 09:05 |
SGH E800 can not get test mode | enrocas | NSPRO | 2 | 04-15-2005 11:01 |
