09-12-2008, 07:26 | #1 (permalink) |
Freak Poster Join Date: May 2008 Location: MX-KEY is the BEST NOKIA TOOL
Member: 775560 Status: Offline Thanks Meter: 58 | error in chinesse miracle 2.60 ! THIS LOG IN PIN FINDER AND CHINESSE MIRACLE software version: 1.14 cable type: 1x14 (L14C) platform: MT: MT62xx (autodetect) searching adapter at COM5... adapter found, version: 2000 pins: 14, plain power cycles: 1 activation cycles: 7 power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Press and HOLD phone Power button now ! detecting pins... 19200 fixed CPU: MT6223 result: Rx:2 Tx:3 time required: 7 sec Power On ! saved: ALTREC_C200 TRY TO READ ==== log: [9/12/2008 1:07:07 PM] ==== COM5 [VCP1] selected Device: Autodetect 6228, 6230 NAND Checking data, wait... Action: read/check detailed information Boot... Press and HOLD Power button now ! baud autodetection active 19200 autodetect Connecting, wait... Initializing[6223:8A04]... CPU: MT6223 high speed boot enabled chip: 0011:251B:000C boot step size: 0400 Release Power button now ! Boot Done Initialize... loader: 3.748.0 error: unknown protocol: 0000 Initialize Fail Finished, time used: 27 sec Remove/Install battery now ! Action: read information Model: Autodetect 6228, 6230 NAND Checking data, wait... Phone should be Switched ON ! Connecting, wait... baud set to: 9600 error: connection failed ! Operation failed ! Finished, time used: 27 sec Power off phone now ! TRY TO READ ==== log: [9/12/2008 1:06:16 PM] ==== COM5 [VCP1] selected Device: Autodetect 6228, 6230 NAND Checking data, wait... Action: read NAND flash read mode: 01 Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6223:8A04]... CPU: MT6223 high speed boot enabled chip: 0011:251B:000C boot step size: 0400 Release Power button now ! Boot Done Initialize... loader: 3.748.0 error: unknown protocol: 0000 Initialize Fail Finished, time used: 25 sec Remove/Install battery now ! TRY READ AGAIN ==== log: [9/12/2008 1:05:39 PM] ==== COM5 [VCP1] selected Device: Autodetect 6228, 6230 NAND Checking data, wait... Action: read NAND firmware read mode: 01 Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6223:8A04]... CPU: MT6223 high speed boot enabled chip: 0011:251B:000C boot step size: 0400 Release Power button now ! Boot Done Initialize... loader: 3.748.0 error: unknown protocol: 0000 Initialize Fail Finished, time used: 26 sec Remove/Install battery now ! ==== log: [9/12/2008 1:05:39 PM] ==== COM5 [VCP1] selected Device: Autodetect 6228, 6230 NAND Checking data, wait... Action: read NAND firmware read mode: 02 Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6223:8A04]... CPU: MT6223 high speed boot enabled chip: 0011:251B:000C boot step size: 0400 Release Power button now ! Boot Done Initialize... loader: 3.748.0 error: unknown protocol: 0000 Initialize Fail Finished, time used: 26 sec Remove/Install battery now ! ==== log: [9/12/2008 1:05:39 PM] ==== COM5 [VCP1] selected Device: Autodetect 6228, 6230 NAND Checking data, wait... Action: read NAND firmware read mode: 03 Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6223:8A04]... CPU: MT6223 high speed boot enabled chip: 0011:251B:000C boot step size: 0400 Release Power button now ! Boot Done Initialize... loader: 3.748.0 error: unknown protocol: 0000 Initialize Fail Finished, time used: 26 sec Remove/Install battery now ! NEED ADVICE FROM PS OR ELSE ! |
09-12-2008, 09:58 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Dear Friend, Please, be more careful when you select phone type. Just check your log and see that you have selected model "Device: Autodetect 6228, 6230 NAND" but phone type is: CPU: MT6223 |
09-12-2008, 11:51 | #3 (permalink) | |
Member: 775560 Status: Offline Thanks Meter: 58 | nice ! Quote:
thanks for you ! you'r the best product suportter , forgive me for my wrong selected model , now i 'll be more carefull ! | |
no show imei change in chiness miracle infinity box | batishd2004 | Infinity-Box | 4 | 07-05-2012 19:16 |
