02-16-2016, 07:14 | #1 (permalink) | |
No Life Poster Join Date: Jun 2007 Location: Gampaha, Srilanka
Member: 527534 Status: Offline Sonork: 100.1606510 Thanks Meter: 193 | Error : DA init Failed! Error code : 0x1 Quote:
02-16-2016, 07:21 | #2 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Hello, Which phone model is this? Download new version v1.41 from support- HERE and try again without pressing any key. Br. Infinity Box Support Team. |
02-16-2016, 08:37 | #3 (permalink) |
Member: 527534 Status: Offline Sonork: 100.1606510 Thanks Meter: 193 | The phone is Panasonic T31 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 83 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x07000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : LOCKED with AUTH Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01 Sending and initialize DA ... [DA_ERROR] : DONE Boot Error! Operation Failed Elapsed: 00:00:06 Reconnect Power/Cable! |
02-16-2016, 09:30 | #5 (permalink) |
Member: 527534 Status: Offline Sonork: 100.1606510 Thanks Meter: 193 | I saw that.... Can you explain what is the meaning of that? Can't we change it to flash with CM2? I mean I couldn't connect before Karbonn Sparkle V without boot loader unlock Or if I haven't do nothing am I flash with SP tool? |
02-16-2016, 09:39 | #6 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
You must use Alcatel upgrade tool for service that phone. In fact - just flash. | |
06-15-2021, 17:28 | #7 (permalink) |
Junior Member Join Date: Apr 2011 Location: manama
Member: 1553442 Status: Offline Thanks Meter: 1 | 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 19 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x9C NAND Flash : NOT INSTALLED eMMC Flash : 90014A4838473165050726900DE573E3 Initialize Memory ... DRAM configured from IDB! DRAM initialize passed! DRAM size : 0x40000000 DAgent sent , init HW now [DA_ERROR] : DA Init failed! Something wrong with battery or connection! Boot Error! Operation Failed Elapsed: 00:01:02 Reconnect Power/Cable! |
