11-16-2015, 13:50 | #1 (permalink) |
No Life Poster Join Date: Jul 2008 Location: Sharja UAE
Member: 820592 Status: Offline Sonork: 100.1590378 Thanks Meter: 327 | Error : DA init Failed! Error code : 0x5 Code: 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 195 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 8801034E436172642034D307296331C3 DA Stat : v4.2 on BBID : 0x87 DRAM not initialized , configure DRAM Settings DRAM EmiReq Ok , 0x00BC Error : DA init Failed! Error code : 0x5 LErr : 00000BBF Boot Error! Operation Failed Elapsed: 00:00:09 Reconnect Power/Cable! Also Getting other Error to other Phone. Code: 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 195 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6583 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6583|6589_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 4900011530305532FAC417418780E766 DA Stat : v3.2 on BBID : 0x86 DRAM not initialized , configure DRAM Settings DRAM EmiReq Ok , 0x00B8 DRAM Init Ok , 0x80000000 DA Sent. Configure setting now ... DA start Failed at final stage! Check battery , cable , drivers and try try again Boot Error! Operation Failed Elapsed: 00:00:02 Reconnect Power/Cable! |
The Following User Says Thank You to Hafiz ArslanAli For This Useful Post: |
11-16-2015, 18:27 | #4 (permalink) | |
Member: 820592 Status: Offline Sonork: 100.1590378 Thanks Meter: 327 | Quote:
just tell me what is the meaning of this Error. Code: Error : DA init Failed! Error code : 0x5 but i am not Compare with other boxes i just want to know what is the meaning of this Code: Error : DA init Failed! Error code : 0x5 Code: DA start Failed at final stage! Check battery , cable , drivers and try try again Boot Error! | |
11-16-2015, 19:07 | #5 (permalink) |
No Life Poster Join Date: Nov 2006 Location: (United States Of Islam) Age: 37
Member: 399832 Status: Offline Sonork: Faheem Anjum Thanks Meter: 24,310 | 0*5 error mean you have erase perloader phone |
The Following User Says Thank You to Faheem Anjum For This Useful Post: |
11-17-2015, 08:48 | #8 (permalink) | |
need to remove Monkey V only but Getting Same error. Code: Operation : Check / Read Info [ v1.37 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 195 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0xFE SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 8801034E436172642032865D866351CD DA Stat : v4.2 on BBID : 0x88 DRAM not initialized , configure DRAM Settings DRAM EmiReq Ok , 0x00A8 Error : DA init Failed! Error code : 0x5 LErr : EMICFG_NOT_FOUND Boot Error! Operation Failed Elapsed: 00:00:05 Reconnect Power/Cable! | |
11-17-2015, 10:13 | #10 (permalink) | |
No Life Poster Join Date: Aug 2006 Location: BHARAT
Member: 327043 Status: Online Sonork: 100.1587811 Thanks Meter: 1,514 | Quote:
1 - don't press any key just insert usb 2- don't use boot cable use simple usb 3- read log waht software say 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. | |
The Following User Says Thank You to sneha For This Useful Post: |
11-18-2015, 09:52 | #11 (permalink) | |
Code: 1 - don't press any key just insert usb | |
11-18-2015, 12:47 | #12 (permalink) | |
but u not read jaydi say about this here http://forum.gsmhosting.com/vbb/11413637-post3.html and u say u tryed all next time for save ur and teams valuable time take 2 minuts and read carefully what jaydi say | |
11-18-2015, 12:52 | #13 (permalink) | ||
Code: DA start Failed at final stage! Check battery , cable , drivers and try try again Boot Error! | ||
