Error detecting sc7730a tablet how to fix Reconnect Power/Cable! Operation : Check/Read Info [ v1.24 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 32 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable Boot failed! DS : Loader start failed! Wrong Model selection! Boot failed! Reconnect Power/Cable! |
Hello, There are 6 boots including 'AltLDR' SPD 7730/31. and also try with SLDR |
Can you explain what is 'AltLDR' and 'SLDR' functions and their meaning ?! |
plus, on each of them, you can "tick" (select) "Alternative LDR Mode", means - 6 tries in total. On some of them, it should boot/connect to software, and you'll be able to do desired operation. Take a try, one by one ... b.r. Alex |
