03-08-2017, 12:26 | #1 (permalink) |
Registered User Join Date: Jul 2013 Location: Harare
Member: 1972271 Status: Offline Sonork: zwanaz Thanks Meter: 164 | Error detecting sc7730a tablet how to fix Operation : Check/Read Info [ v1.24 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 32 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable Boot failed! DS : Loader start failed! Wrong Model selection! Boot failed! Reconnect Power/Cable! |
The Following User Says Thank You to zwanaboy For This Useful Post: |
03-08-2017, 12:55 | #2 (permalink) |
No Life Poster Join Date: Apr 2009 Location: Inside Infinity
Member: 1010626 Status: Offline Sonork: using fb Thanks Meter: 735 | Hello, There are 6 boots including 'AltLDR' SPD 7730/31. and also try with SLDR |
The Following User Says Thank You to princesaddam For This Useful Post: |
03-09-2017, 00:19 | #4 (permalink) | |
Member: 163 Status: Offline Thanks Meter: 7,784 | Quote:
plus, on each of them, you can "tick" (select) "Alternative LDR Mode", means - 6 tries in total. On some of them, it should boot/connect to software, and you'll be able to do desired operation. Take a try, one by one ... b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! | |
The Following 2 Users Say Thank You to Brka For This Useful Post: |
