01-13-2020, 16:55 | #1 (permalink) |
Freak Poster Join Date: Feb 2008 Location: uganda
Member: 705986 Status: Offline Thanks Meter: 11 | Error : Device NOT INITIALIZED ! Initialize it first via "IDENTIFY" ! Make sure you have made "IDENTIFY" first! Operation : Repair Security [ v2.04 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC7715_BASE : SC7715_eMMC_512MB_NS Sending Init Boot ... Boot sent! Kick FDL ... Kick FDL again ... Device not found! Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! Operation : Repair Security [ v2.04 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC9863x_BASE : SC9863_eMMC_2GB_RS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! Error : Device NOT INITIALIZED ! Initialize it first via "IDENTIFY" ! Make sure you have made "IDENTIFY" first! Reconnect Power/Cable! |
01-13-2020, 16:57 | #2 (permalink) |
Member: 705986 Status: Offline Thanks Meter: 11 | the identify operation successful Operation : Identify [ v2.04 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC9863x_BASE : SC9863_eMMC_2GB_RS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! UserData : STATE : DAMAGED Done! Elapsed: 00:01:33 |
01-13-2020, 17:02 | #3 (permalink) |
Member: 705986 Status: Offline Thanks Meter: 11 | read firmware operation failed after identfy Operation : Read FW [ v2.04 ] 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC9863x_BASE : SC9863_eMMC_2GB_RS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! Error : Device NOT INITIALIZED ! Initialize it first via "IDENTIFY" ! Make sure you have made "IDENTIFY" first! Reconnect Power/Cable! |
01-13-2020, 17:06 | #4 (permalink) |
Member: 705986 Status: Offline Thanks Meter: 11 | repair security operation also give same error Operation : Repair Security [ v2.04 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : INF : 0_SC9863x_BASE : SC9863_eMMC_2GB_RS Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : Control transfered! Boot Done! Error : Device NOT INITIALIZED ! Initialize it first via "IDENTIFY" ! Make sure you have made "IDENTIFY" first! Reconnect Power/Cable! |
01-13-2020, 17:08 | #5 (permalink) | |
Member: 705986 Status: Offline Thanks Meter: 11 | Quote:
01-14-2020, 17:06 | #9 (permalink) |
Member: 705986 Status: Offline Thanks Meter: 11 | people please help. it is really urgent. the phone brand is blu g5 plus. but only operations that work is factory reset and privacy reset. the rest dont work. help please |
01-16-2020, 17:34 | #14 (permalink) |
Member: 705986 Status: Offline Thanks Meter: 11 | what do you mean "you have factory firmware" i have tried to search online but have not found firmware. I have two sets. I want to read firmware from one and flash to another that keeps rebooting |
01-16-2020, 18:06 | #15 (permalink) | |
No Life Poster Join Date: Dec 2004 Location: Uganda Age: 45
Member: 96478 Status: Offline Sonork: 100.1674604 Thanks Meter: 1,420 | Quote:
Which Android version or KAIOS DEVICE? | |
