05-28-2009, 18:16 | #1 (permalink) |
No Life Poster Join Date: Feb 2005 Location: HOME OF PEACE
Member: 113732 Status: Offline Thanks Meter: 90 | error: error# 0000FFFF in imei repair I follow all the instruction to solve this problem but same. Now i can't even flash back the backup flash & eeprom. it will write error. COM6 [VCP0] selected module v2.74 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: "repair imei" imei write method: mode-3 imei write channel: imei #1 for dual sim/mono CPU new imei: 340460108004040 ffs/eeprom backup enabled, it may takes several minutes ! Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:F903:0009 boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 98000300000000:18E59F00000000 flash: AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #01 in region #00... flash: 98000300000000:18E59F00000000 flash: AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud ... 460800 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 98000300000000:18E59F00000000 flash: AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #01 in region #00... flash: 98000300000000:18E59F00000000 flash: AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw 1: HEXING25_GEMINI_PCB01_GPRS_MT6225_S00.B011_2_W08_1 2_01.BIN ver. sw 2: B011_2.W08.12.01, 00000000 ffs offset/size: 00E00000/00200000 detecting security area (code #2)... .................................................. .................................................. ............................ security area (code #2) is absent detect device identification#2... detection phase #1... . detect device identification#2 finished detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 flash: 98000300000000:18E59F00000000 checking area [00000000]: 00000000-00FFFFFF... ffs/eeprom found near: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: eeprom[HEXING25_GEMINI_PCB01_GPRS_MT6225_S00.B011_2_W08_1 2_01.BIN]... file saved: C:\Program Files\InfinityBox\ChineseMiracle\eeprom[HEXING25_GEMINI_PCB01_GPRS_MT6225_S00.B011_2_W08_1 2_01.BIN]_20090528-173435.B0E.bin flash: 98000300000000:18E59F00000000 Backup required data Done Patch required data ... 2 step(s) required Patch required data Done Special operation ... Special operation Done Write ... flash: 98000300000000:18E59F00000000 Write: eeprom error: error# 0000FFFF error: flash write error: 00E00000:00002000 error: error# 0000FFFF error: flash write error: 00E00000:00002000 error: error# 0000FFFF error: flash write error: 00E00000:00002000 Write Fail Finished, time used: 148 sec Remove/Install battery now ! HELP |
06-01-2009, 00:02 | #6 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! please use lastest chinese miracle module the one which you using do not support this flash IC |
06-04-2009, 17:15 | #7 (permalink) | |
Member: 113732 Status: Offline Thanks Meter: 90 | Quote:
I used normal downloading, it will just cut in any percent and show download complete. I already tried downloading bits by pieces up to five only. Any problem with the site. | |
06-04-2009, 23:03 | #8 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! latest Chinese Miracle module is available to download separatly. also, if you still wish to get Main Setup, you can try different mirror servers. maybe on them you will get better or more stable connection |
bug in imei repair | mscomp | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 3 | 02-04-2010 00:05 |
how in imei repair with ChineseMiracle v2.66 | neo.com | Infinity-Box | 3 | 11-04-2008 23:06 |
It´s Posible IMEI REPAIR in Alcatel 0.T 535?¿?¿ | Grupo MovilFree | BF, BG, TH, BHx Series | 1 | 07-21-2004 00:09 |
T66 imei repair or need full flash for T66 in BIN format | Kvant | Sony Ericsson | 5 | 01-16-2004 04:01 |
