Old 11-11-2018, 16:05   #1 (permalink)
Member: 980481
Thanks Meter: 14
Error : Failed erase block! CRO-U00
Card found : xxxxxxxxxx, v0137
Infinity-Box Chinese Miracle MediaTek Service Module [ MTK ] v2.02
Load IDBase v11861 Ok!
Update configuration ...
Update Ok!
Operation : Identify [ v2.02 ]
1. Make sure device is powered off. Power off, if need. Wait 20 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : MediaTek PreLoader USB VCOM_V1632 (Android) (COM5)
MODE : PRELOADER PORT
PORT : 5
Waiting BOOT ack ...
PRELOADER : ACK confirmed!
BROM : Init BROM
BROM init passed!
     CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000
     TYPE : LEGACY MTK
BROM : SecLevel : 0x00000005
BROM : SecMode  : SBC+SDA
BROM : PRELOADER PORT
MODE : 0_base : BASE_v1712 | Manual : Disabled
AGENT : Look for suitable BootChain in DA ...
AGENT : MTK_AllInOne_DA.bin
AGENT : Found MT6580
AGENT : MTK_DOWNLOAD_AGENT
     BROM : Sending 1st DA ...
  BROM  : 0x00002001 : DA SEND ERROR!
  ERROR : SECURE BOOT : MISMATCH BOOT SIGNATURE!
  INFO : PRELOADER Level : CORRECT DA required : PL/PL_CRYPTO
Error : Fail to init protocol!
Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation!
Reconnect Power/Cable!
Device not found!
Check cable, battery, connection and drivers!
PORT : 5
BROM : Init BROM
BROM init passed!
     TYPE : LEGACY MTK
MODE : Huawei : TIT-series | Manual : Enabled
AGENT : CRO_U00_Boot.bin
BROM : DA sent
BROM :Transfer control to DA ...
     DA : AGENT started!
NAND : DEVICE NOT FOUND
eMMC : OK
eMMC : 484A019061344738124FD43267844B30
DAInf: 4 : 2 : 148
     DA : DRAM ready!
DA : BOOT to 2nd DA ...
DA : Receiving HW info
        EMMC: 90014A483847346132D44F12304B8467
        EMMC: VEN : HYNIX | OEM : 4A01 | DEV : H8G4a2
        EMMC:
              BOOT1  : 0x00400000 [ 4.00 MB ]
              BOOT2  : 0x00400000 [ 4.00 MB ]
              RPMB   : 0x00400000 [ 4.00 MB ]
              USER   : 0x1D2000000 [ 7.28 GB ]
        SRAM: 0x00020000 [ 128.00 KB ]
        DRAM: 0x40000000 [ 1.00 GB ]
        CHIP : MT6580 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000
        RNID : B9902D0D1AFE7F1F4A959FB763350CB6
 STATUS : BLANK FLASH
 BSTYLE : EMMC FLASH BOOT
DA : USB : HIGH-SPEED
Boot done!
Patch Level    : HUAWEICRO-U00
Ver. CodeName  : REL
Ver. Release   : 6.0
Sec. Patch     : 2018-08-05
Build Time     : 1534159827
Product Model  : CRO-U00
Product Brand  : HUAWEI
Product Name   : CRO-U00
Product Device : HWCRO-U6580M
Product Board  : CRO-U00
Product Manfct : HUAWEI
Board Platform : mt6580
Product Info   : CRO-U00
Display ID     : Cairo-U00C185B128
USERDATA : PLAIN ( NOT encrypted )
Done!
Elapsed: 00:00:15
Operation : Reset Settings/Format FS [ v2.02 ]
PORT : 5
BROM : Init BROM
BROM init passed!
     TYPE : LEGACY MTK
BROM : DA sent
     DA : AGENT started!
eMMC : OK
DAInf: 4 : 2 : 148
     DA : DRAM ready!
        EMMC:
Boot done!
ERR : 0x0000177C
ERR : SECURITY : SF CODE FORMAT FORBIDDEN
ERR : 0x00000000|0x00000000
Try select another format mode!
Old 11-11-2018, 20:57   #2 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 15,925
Change GLOBAL mode ( in first tab, under identify and connection mode settings tp ADR ( second option ))
Init memory Tool , Wipe FRP partition.
The Following User Says Thank You to JayDi For This Useful Post:
Old 11-11-2018, 21:24   #3 (permalink)
rebainoor's Avatar
Member: 231728
Thanks Meter: 1,365
and you need rework secro if you know what is this........
Page generated in 0.23915 seconds with 7 queries
