12-14-2016, 00:05 | #1 (permalink) |
Freak Poster Join Date: Oct 2009
Member: 1143383 Status: Offline Thanks Meter: 53 | Error : FH Configuration failed! The "Read FW" operation was successfully performed on a Huawei Y530-U00, without the battery inserted. The operation "FLASH" started well until about 30% then it stopped, I do not know for what reason. The battery is still not inserted. I have repeated n times the flashing but without success following the error here. --------------------------------------------------------------- Operation : Flash [ v1.04 ] Verify FW package ... Verification passed! 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 2x/4x|00 [MSM8x10] ID_BLOCK_S : 01030395 ID_BLOCK_I : 008110E1 ID_BLOCK_L : 5BF3348E763AA224 ID_BLOCK_L : C060A78CDE6993E8 Pickup loader from firmware package Loader Sent! Initializing ... Error : FH Configuration failed! Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! ----------------------------------------------------------- What is the cause of this error ? How to get out ? (I specify that the cable is good but that the battery was not inserted). |
12-14-2016, 00:56 | #2 (permalink) |
No Life Poster Join Date: Aug 2010 Location: Inside Logic Age: 37
Member: 1377783 Status: Offline Sonork: 100.1611724 Thanks Meter: 3,336 | Hi, huawei qualcomm model have a diferent structure for flashing, even you need be sure that you are upgrading with exactly rom version.... in addition, bootloader is locked... Best Regards Shensohau |
The Following 2 Users Say Thank You to Shensohau For This Useful Post: |
