06-04-2010, 20:42 | #1 (permalink) |
No Life Poster Join Date: Nov 2007 Location: Central America
Member: 628110 Status: Offline Thanks Meter: 87 | [ERROR] Flash Backup HUAWEI G5730 CLARO GT MAKING BACKUPS Code: COM4 [VCP0] selected module v3.14 Device: Autodetect 6228-6239 NAND Checking data, wait... Action: read firmware NAND interface: BROM_DLL_v3.952.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8A04:8A01 status: FF bbchip bl ver: FE NOR flash id[00A1]: 0098:000300000000 [TOSHIBA] TC58FVM7TDD chip size: 16Mb otp status/size: S_DA_NOR_OTP_NOT_SUPPORT/00000000 NAND flash chip: not installed internal RAM size: 00010000 external RAM [HW_RAM_SRAM, CS1] size: 00800000 done Set baudrate (921600)... done ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 00000000/00000000 detect sec ro... detect custom parameters... detect project-id... project-id: ENGC64B148 detect NOR info... number of areas/bytes to read: 1:00040000 reading (HW_STORAGE_NOR)... TCL-ID detection... TCL-ID detection done startup code area #1 detection... number of areas/bytes to read: 1:00004000 reading (HW_STORAGE_NOR)... number of areas/bytes to read: 1:00004000 reading (HW_STORAGE_NOR)... startup code area #1 is valid startup code area #1 detection done rom info ver: 05 sw version: HUAWEI35_08B_PCB01_GPRS_MT6235B_S01.ENGC64B148.BIN project-id: ENGC64B148, 6FB6CFA8 code offset: 00000000 ffs offset/size [01]: 00D00000/00300000 rom info structure: 2nd [enhanced] generation TCL-ID is absent ===> done ==================== New firmware detected (v.3.14, database date: 28.05.2010): HUAWEI35_08B_PCB01_GPRS_MT6235B_S01.ENGC64B148.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== area size: 13Mb number of areas/bytes to read: 1:00D00000 reading (HW_STORAGE_NOR)... file saved: C:\Program Files (x86)\InfinityBox\ChineseMiracle\HUAWEI35_08B_PCB01_GPRS_MT6235B_S01.ENGC64B148__firmware_20100604-132748.B4M.bin Disconnect... done file saved: C:\Program Files (x86)\InfinityBox\ChineseMiracle\backup_security\HUAWEI35_08B_PCB01_GPRS_MT6235B_S01.ENGC64B148__system_log_20100604-133001.B4X.bin Finished, time used: 9 min 10 sec Remove/Install battery now ! Code: COM4 [VCP0] selected module v3.14 Device: Autodetect 6228-6239 NAND Checking data, wait... Action: read flash NAND interface: BROM_DLL_v3.952.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8A04:8A01 status: FF bbchip bl ver: FE NOR flash id[00A1]: 0098:000300000000 [TOSHIBA] TC58FVM7TDD chip size: 16Mb otp status/size: S_DA_NOR_OTP_NOT_SUPPORT/00000000 NAND flash chip: not installed internal RAM size: 00010000 external RAM [HW_RAM_SRAM, CS1] size: 00800000 done Set baudrate (921600)... done ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 00000000/00000000 detect sec ro... detect custom parameters... detect project-id... project-id: ENGC64B148 detect NOR info... number of areas/bytes to read: 1:00040000 reading (HW_STORAGE_NOR)... TCL-ID detection... TCL-ID detection done startup code area #1 detection... number of areas/bytes to read: 1:00004000 reading (HW_STORAGE_NOR)... number of areas/bytes to read: 1:00004000 reading (HW_STORAGE_NOR)... startup code area #1 is valid startup code area #1 detection done rom info ver: 05 sw version: HUAWEI35_08B_PCB01_GPRS_MT6235B_S01.ENGC64B148.BIN project-id: ENGC64B148, 6FB6CFA8 code offset: 00000000 ffs offset/size [01]: 00D00000/00300000 rom info structure: 2nd [enhanced] generation TCL-ID is absent ===> done ==================== New firmware detected (v.3.14, database date: 28.05.2010): HUAWEI35_08B_PCB01_GPRS_MT6235B_S01.ENGC64B148.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== area size: 16Mb number of areas/bytes to read: 1:01000000 reading (HW_STORAGE_NOR)... file saved: C:\Program Files (x86)\InfinityBox\ChineseMiracle\HUAWEI35_08B_PCB01_GPRS_MT6235B_S01.ENGC64B148__fullflash_20100604-133847.B4M.bin Disconnect... done file saved: C:\Program Files (x86)\InfinityBox\ChineseMiracle\backup_security\HUAWEI35_08B_PCB01_GPRS_MT6235B_S01.ENGC64B148__system_log_20100604-133900.B4X.bin Finished, time used: 8 min 34 sec Remove/Install battery now ! FLASH BACKUPS... Code: COM4 [VCP0] selected module v3.14 Device: Autodetect 6228-6239 NAND Checking data, wait... Action: write flash NAND write: Firmware HUAWEI35_08B_PCB01_GPRS_MT6235B_S01.ENGC64B148__firmware_20100604-132748.B4M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs nfi area detection... warning: incorrect header: 3B0000EA18F09FE518F09FE518F09FE5 warning: can not detect header nfi area detection finished: failed error: unknown source file structure Finished, time used: 1 sec Remove/Install battery now ! Code: COM4 [VCP0] selected module v3.14 Device: Autodetect 6228-6239 NAND Checking data, wait... Action: write flash NAND write: Firmware HUAWEI35_08B_PCB01_GPRS_MT6235B_S01.ENGC64B148__firmware_20100604-132748.B4M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs nfi area detection... warning: incorrect header: 3B0000EA18F09FE518F09FE518F09FE5 warning: can not detect header nfi area detection finished: failed error: unknown source file structure Finished, time used: 1 sec Remove/Install battery now ! DOWNLOAD HUAWEI G5730 CLARO GT.rar |
The Following User Says Thank You to WeBoXGT For This Useful Post: |
06-04-2010, 20:49 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, This phone has NOR flash only so you can read NOR but can not read NAND. Please, try to make "read unlock codes" operation. What is the results ? Also, what pinout you have used ? |
06-04-2010, 21:03 | #3 (permalink) | |
Member: 628110 Status: Offline Thanks Meter: 87 | Quote:
ok, 2rx 3tx Code: COM4 [VCP0] selected module v3.14 Action: read unlock codes unlock method: read codes Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6235:8A04:8A01]... CPU: MT6235 high speed boot On chip: 0000:0000:0003 status: FF rom: 4D453032 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6235,E04 Date: 2000.00.00 Version: 1.0 Version: ENGC64B148 Version: VER.A detecting structure #2... 1 2 3 5 7 8 9 11 13 done 80 byte(s) read imei: 86279500014628 connection Ok detecting structure #1... 0 3 4 7 9 12 13 14 15 16 19 20 23 25 28 29 31error: detection failed (16 tries), read flash and send to support error: can't read required data error: operation failed ! Finished, time used: 14 sec Remove/Install battery now ! | |
06-04-2010, 21:07 | #4 (permalink) |
Member: 628110 Status: Offline Thanks Meter: 87 | Code: COM4 [VCP0] selected module v3.14 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: read firmware ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6235:8A04:8A01]... CPU: MT6235 high speed boot On chip: 0000:0000:0003 status: FF boot packet size: 0400 Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" Boot Fail Finished, time used: 12 sec Remove/Install battery now ! |
06-04-2010, 21:11 | #5 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, please, keep phone with you for 1 more day, we will try to give you updated software for tests ASAP. |
06-04-2010, 21:36 | #7 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Please, try to unlock phone with this software: http://www.infinity-box.com/download...v3.42_ver1.rar use "smart fast" unlock method. Waiting for your results |
06-04-2010, 21:42 | #8 (permalink) | |
the problem is, the good phone sold out, the bad phone have here...waiting for flash | |
06-04-2010, 22:03 | #9 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | I am not sure that it will be possible to flash phone due to some problems. Anyway, we will upload flash files for this model now. |
06-08-2010, 22:17 | #12 (permalink) | |
No Life Poster Join Date: Nov 2005
Member: 199538 Status: Offline Thanks Meter: 54 | Not unlock !!! BLINKING !!! Quote:
after unlock OK,,, with this mmodule 3.42... ,, when i insert original SIM or without SIM not problem with network,, all phone work OK... but When i insert other SIM.. phone BLINK and restar in LOGO startup .. any idea... .. waiting... here logs below .. COM6 [VCP0] selected module v3.42 Action: "sp-unlock" unlock method: smart fast Model: Huawei-G5730 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6235:8A04:8A01]... CPU: MT6235 chip: 0000:0000:0003 status: FF rom: 4D453032 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6235,E04 Date: 2000.00.00 Version: 1.0 Version: ENGC65B141 Version: VER.A 80 byte(s) read imei: 35528903020073 connection Ok 185 byte(s) read reading data... reading data #2... building new data... writing data... 173 byte(s) read reading data... 972 byte(s) read building new data... writing data... verifying... verification Ok done Finished, time used: 14 sec Remove/Install battery now ! | |
The Following User Says Thank You to humbedj For This Useful Post: |
need to flash 6110 | paulomt1 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 08-16-2019 19:37 |
5110 flash new software , need help | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 01-03-2015 05:41 |
where to find a working program all they have some errors ?? | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 12-12-2012 13:26 |
error (1002) simlock3.dll winopen | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 08-28-1999 15:57 |
