04-23-2010, 17:34 | #5 (permalink) |
Freak Poster Join Date: Jul 2004 Location: Ukraine
Member: 74053 Status: Offline Thanks Meter: 75 | ==== [22.04.2010 15:58:32] ==== COM4 selected module v3.12 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active write: Firmware editor_corrected_E806_CR1_EVCOM_MT6225S00.01_1_200 91021__fullflash_20100422-154457.B0M.bin.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:3803:0007 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC240200000000:18E59F00000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 detecting chip #01 in region #00... flash: EC240200000000:18E59F00000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 detecting chip #02 in region #00... flash: EC240200000000:18E59F00000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 detecting chip #03 in region #00... flash: EC240200000000:18E59F00000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: EC240200000000:18E59F00000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 detecting chip #01 in region #00... flash: EC240200000000:18E59F00000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is absent rom info detection finished rom info ver: 04 sw version: E806_CR1_EVCOM_MT6225S00.01_1_20091021.BIN project-id: E806_CR1.01.1, 00000000 code offset: 00000000 ffs offset/size [01]: 01C00000/00400000 rom info structure: 2nd [standard] generation TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset assigned: 00E00000 standard ffs/eeprom offset confirmed: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: E806_CR1_EVCOM_MT6225S00.01_1_20091021__ffs... file saved: C:\Program Files\InfinityBox\ChineseMiracle\E806_CR1_EVCOM_MT 6225S00.01_1_20091021__ffs_20100422-160023.B0E.bin flash: EC240200000000:18E59F00000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... sec info (fast) detection... searching sec info#1... . search sec info#1 finished usb bootloader (file) is absent startup code area #1 check... startup code area #1 fixed detecting startup code area #2... startup code area #2 is absent Area: Firmware flash: EC240200000000:18E59F00000000 Write: Firmware error: error# 000000FF error: flash write error: 00C30000:00002000 error: wrong answer: B0 error: flash write error: 00C30000:00002000 error: no any expected answer error: flash write error: 00C30000:00002000 error: write operation failed Write Fail Finished, time used: 3 min 22 sec Remove/Install battery now ! |
04-23-2010, 17:38 | #6 (permalink) |
Member: 74053 Status: Offline Thanks Meter: 75 | New phone, same flash but work OK ==== [23.04.2010 19:11:39] ==== COM4 selected module v3.12 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active write: Firmware editor_corrected_KCM25_GEMINI_PCB01_GPRS_MT6225_S0 0.MAUI_GEMINI_W08_12__fullflash_20100423-174031.B0M.bin.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:CA03:000B status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC240200000000:18E59F00000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 detecting chip #01 in region #00... flash: EC240200000000:18E59F00000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 detecting chip #02 in region #00... flash: EC240200000000:18E59F00000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 detecting chip #03 in region #00... flash: EC240200000000:18E59F00000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: EC240200000000:18E59F00000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 detecting chip #01 in region #00... flash: EC240200000000:18E59F00000000 flash: Samsung K5L2833ATA T 16Mb otp offset: 00FF0000 it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is absent rom info detection finished rom info ver: 04 sw version: KCM25_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_GEMINI_W08 _12.BIN project-id: MAUI.GEMINI.W08.12, 00000000 code offset: 00000000 ffs offset/size [01]: 00F00000/00100000 rom info structure: 2nd [standard] generation TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00F00000 standard ffs/eeprom offset confirmed: 00F00000 detecting ffs/eeprom size... ffs/eeprom size: 00100000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00F00000-00FFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: KCM25_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_GEMINI_W08 _12__ffs... file saved: C:\Program Files\InfinityBox\ChineseMiracle\KCM25_GEMINI_PCB0 1_GPRS_MT6225_S00.MAUI_GEMINI_W08_12__ffs_20100423-191246.B0E.bin flash: EC240200000000:18E59F00000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... sec info (fast) detection... searching sec info#1... . search sec info#1 finished usb bootloader (file) is absent startup code area #1 check... startup code area #1 fixed detecting startup code area #2... startup code area #2 is absent Area: Firmware flash: EC240200000000:18E59F00000000 Write: Firmware sec info (fast) detection... searching sec info#1... . search sec info#1 finished Write Done ====> Finalization ... Finalization Done Finished, time used: 4 min 14 sec Remove/Install battery now ! |
5110 flash new software , need help | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 01-03-2015 05:41 |
where to find a working program all they have some errors ?? | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 12-12-2012 13:26 |
£2,000 for 5110/6110 unlock software 1 2 3 4 | Dean O'Grady | Wanted Products | 14 | 03-19-2005 10:52 |
I CAN UNLOCK 1,2,3,4 FOR ANY PHONE £40 (1+) -- £30 (20+) | andrew bennett | Main Sales Section | 1 | 07-26-1999 19:33 |
