04-14-2007, 06:22 | #1 (permalink) |
Freak Poster Join Date: May 2005 Location: Brunei
Member: 145396 Status: Offline Thanks Meter: 218 | Error Flashing x400, x700 Testing COM2 at 115200... Device: X700,X701 Checking data, wait... Action: Flash write Boot... Press Power button now ! Err: wrong Boot answer1: Boot Failed Finished Remove/Install battery now ! Time used: 56 sec Com-2 serial0 detected, is this correct? x60 cable type is used connected to left RJ45 jack but no light green blinking.. Please dont refer me to previous link coz ive read it but not detailed... mostly unlocking... I'm looking forward for immediate response from infinity team... BR |
04-14-2007, 08:39 | #3 (permalink) | |
Product Supporter Join Date: Sep 2004 Location: *In the right way*
Member: 84268 Status: Offline Sonork: 100.114149 Thanks Meter: 2,569 | Quote:
x700 not the same as x60 ( x60 cable type is used connected to left RJ45 jack ) ================================ o_o_o_o_o_o_o_o_o_o_o_o___o_o 1...14 1: Gnd (USB ground) 2: Rx 3: Tx 10: USB-White 11: USB-Green 12: USB-Red (USB power) X700 COM cable use pin 1,2,3 X700 USB cable use pin 1,10,11,12 | |
04-14-2007, 09:08 | #4 (permalink) |
Member: 145396 Status: Offline Thanks Meter: 218 | @ zinoubilabil Thanks for your reply, yeah i have cable for x70 and i use to flash x700 but still same logs as i flash x400... boot failed... what is the posible ways? TIA |
04-14-2007, 10:05 | #6 (permalink) |
Member: 84268 Status: Offline Sonork: 100.114149 Thanks Meter: 2,569 | also check this link http://forum.gsmhosting.com/vbb/show...67&postcount=3 |
04-14-2007, 17:36 | #8 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @maui_1856 you must read info at official site before ask questions that has no answer, so please, check www.infinity-box.com to see list of supported models/functions and you can see that: X700 flashing not supported by Infinity-Box. If you can use "search" button you no need to "I'm looking forward for immediate response from infinity team..." because you can get an answer in 2 minutes by yourself. X400: what is the problem exactly ? |
04-14-2007, 18:39 | #9 (permalink) |
Member: 145396 Status: Offline Thanks Meter: 218 | @InfinitySupport; Thanks for your reply, and i'm hoping that you guide me correctly because we have two infinity boxes put only in the drawer because its not easy to use, yeah i understand and i'm sorry i dont have enough time to search that's why i'm asking for immediate response but do hope you dont get mad about asking immediate coz i'm not same as you know everything, ive notice in panasonic have x700 and have eeprom option for flashing but i didnt know its not supported but then why you response not freindly? better no option for x700 right? i'm asking coz i dont know, to whom i've ask? i'm the product user, your the supporter, better i'll burn this boxes rather than no right answer from support... I'm asking for immediate response coz its urgent... If you read also clearly my post you no need to ask the problem of x400? |
04-14-2007, 18:44 | #10 (permalink) |
04-14-2007, 19:13 | #12 (permalink) |
Member: 145396 Status: Offline Thanks Meter: 218 | Action: Flash write Boot... Press Power button now ! Err: wrong Boot answer1: Boot Failed Finished Remove/Install battery now ! Time used: 56 sec since x700 is not suported, this log is same as i've flash x400, i cant flash just PRESS POWER BUTTON NOW but then even ive press more then 10 sec, or a minute for several times with my two boxes its the same, x400 problem is, when you switch it on it lights only and if you release it its off... i've tried also to read a good x68 but still same situation... I'm using the two type of cables, the x60 and with the 4 strips one... i'm noobs for infinity please excuse me, i dont have any intension to hurt anyone i want this boxes working coz its expensive and its useless if nobody will guide me... i'm also using cruiser, setools, jaf, ufs, gti, smartclip but its friendly to use... TIA |
04-14-2007, 19:51 | #13 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @maui_1856 according to your x400 problem description I can give you the next advices: 1. select correct COM port ! 2. use correct cable, cable with "X60" mark ! 3. make unlock operation 4. make reset operation 5. flash phone also please, explain me what is the problem with not friendly use of Infinity-Box ? Please, I need to know facts bu not only words like "not friendly to use, that's all" because if ypou can explain what is the problem we can guide you how to solve your problem, but if you can't explain what is exact problem all your words is just a words. also, please, see FAQ thread: http://forum.gsmhosting.com/vbb/showthread.php?t=342807 You can see a lot of very good descriptions for different problems. Common problems: .COM port selection (PC Device Manger): .Box settings/switches: .Problem with initial phone connection: .Software can't detect phone: .No answer (wrong answer) from phone after "Connecting, wait...": http://forum.gsmhosting.com/vbb/showthread.php?t=200078 Hope you will try to follow my advices and you will give me more detailed problem description after you will truy to solve the problem according to my advicews. |
04-15-2007, 03:10 | #14 (permalink) | |
Member: 145396 Status: Offline Thanks Meter: 218 | Quote:
Thank you very much freind, highly appreciated for your detailed response, i post result... Morepower to you! | |
sim error model X400 | fone | Panasonic | 1 | 03-29-2007 10:11 |
i need flash pana x700 | tumudon | Panasonic | 0 | 08-25-2006 18:53 |
sim error for X400 | fone | Panasonic | 0 | 05-04-2006 16:30 |
need flash X400 in chinese | nc2000 | Trident/AGERE Platform | 0 | 03-10-2004 09:16 |
need flash X400 in french | Marsu168 | Trident/AGERE Platform | 0 | 02-20-2004 17:11 |
