-   Infinity-Box (http://forum.gsmhosting.com/vbb/f296/)
-   -   error in format and unlock (http://forum.gsmhosting.com/vbb/f296/error-format-unlock-1002934/)
X-TRA 05-18-2010 15:21
when i unlock the set its in invalid sim but its gives error
here is log
COM11 [VCP0] selected
module v3.11
Action: read unlock codes
unlock method: read codes
Model: Autodetect 6205-6227 NOR
Checking data, wait...
19200 autodetect
Initializing [6225:8A05:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:8003:0009
status: FF
Connecting at 19200, wait...
Release Power button now !
Phone detected, wait...
Hardware: MT6225,E05
Date: 2006.06.14
Version: 1.0
Version: MAUI.08B.W08.52.MP.V2.090905
Version: F25_08B_GEMINI_HW
detecting structure #2...
1 2 3 5 7 8 9 11 13 done
80 byte(s) read
imei: 35169501989882
connection Ok
detecting structure #1...
0 2 3 4 7 9 12 13 15 16 18 19 20 23 25 28 29 31error: detection failed (18 tries), read flash and send to support
error: can't read required data
error: operation failed !
Finished, time used: 10 sec
Remove/Install battery now !
X-TRA 05-19-2010 09:46
still wait from infinity
its LC M508 MODEL
X-TRA 05-20-2010 14:16
@mr infinity would you please answer me can you help me on this problem or not please AT LEAST you say me no
InfinityHelp 05-21-2010 09:51
hello!
try to make Format FFS complete instead of SAFE
X-TRA 05-21-2010 13:33
here is complete ffs but still on invalid sim
here islog
module v3.11
Device: Autodetect 6205-6227 NOR
Action: reset settings ("format ffs")
ffs/eeprom backup enabled, it may takes several minutes !
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
high speed boot On
status: FF
boot packet size: 0400
Boot Done
====> Initialize ...
flash: EC257E25082501:18E59F00000000
flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
otp offset: 00000000
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
====> Set baud ...
921600
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
device parameters detection in progress...
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: 2nd [standard] generation
TCL-ID is absent
rom info detection finished
rom info ver: 05
sw version: HEXING25_08B_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_08B _W08_52_MP_V2_090905.BIN
project-id: MAUI.08B.W08.52.MP.V2.090905, 00000000
code offset: 00000000
ffs offset/size [01]: 00E00000/00200000
TCL-ID is absent
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00E00000
standard ffs/eeprom offset confirmed: 00E00000
detecting ffs/eeprom size...
ffs/eeprom size: 00200000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E00000-00FFFFFF
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
reading: HEXING25_08B_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_08B _W08_52_MP_V2_090905__ffs...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\HEXING25_08B_GEMI NI_PCB01_GPRS_MT6225_S00.MAUI_08B_W08_52_MP_V2_090 905__ffs_20100521-161940.B0E.bin
Backup required data Done
====> Patch required data ...
Patch required data Done
====> Special operation ...
Special operation Done
====> Write ...
Write Done
====> Finalization ...
ffs formatting...
Finalization Done
Finished, time used: 2 min 23 sec
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
InfinityHelp 05-24-2010 08:31
hello!
make full backup and try to flash phone with available on support pair of flash+ffs
X-TRA 05-24-2010 10:07
its done with another software
YellowBoss 05-24-2010 14:26
here is log
module v3.11
19200 autodetect
CPU: MT6225
high speed boot On
status: FF
Date: 2006.06.14
Version: 1.0
80 byte(s) read
connection Ok
Next time in case of any problems, please, follow this easy rule: read text given by software.
X-TRA 05-25-2010 10:03
yes i read it and this is the software bug not any fault from ma end
Page generated in 0.19336 seconds with 5 queries
