Old 12-09-2016, 18:04   #1 (permalink)
Member: 1120289
Thanks Meter: 135
error imei repair
Operation : Repair Security [ v1.58 ]
Wait for phone...
Phone found! [ 108 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BB_CPU_NME : [MediaTek] MT6582_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x87
NAND Flash : NOT INSTALLED
eMMC Flash : 45010044533230303801931D20884229
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x45 , OEM : 0100
[eMMC] : FLASH_INF : [SANDISK] , 8002S
[eMMC] : FLASH_CID : 45010044533230303801931D20884229
[eMMC] : FLASH_LEN : 0x00000001D2000000
[eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB]
DEV RID : 0x57EF5E7ECCDAA1A1061C846A334B9F97
INT RAM : 0x00020000
EXT RAM : 0x40000000 [1 GiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Error on Security Repair , Code : 0x1
Make sure about mobile is working and alive!
Check BaseBand state also, fix if need!
Operation Failed
Elapsed: 00:00:17
Reconnect Power/Cable!
Old 12-10-2016, 09:23   #2 (permalink)
PASSIONATE_BOYS's Avatar
Member: 541591
Sonork: 100.1611509
Thanks Meter: 6,975
Hello,
Check Baseband, if unknown then flash or repair Baseband first.
Br.
Infinity Box Support Team.
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post:
Page generated in 0.15365 seconds with 7 queries
