03-09-2016, 12:48 | #1 (permalink) |
No Life Poster Join Date: Sep 2011 Location: Faislabad Age: 34
Member: 1657674 Status: Offline Thanks Meter: 855 | Lenovo A2010-a Read Flash Done cm2 1.40 & 1.42-1.43 ver Error _ver 1.40 100% work 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6735 BB_CPU_HW : CA00 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6735_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 510001154D533237EDD70042DF9B6FD6 DA Stat : v4.2 on BBID : 0x93 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMS27 [eMMC] : FLASH_CID : 150100513732534D4200D7EDD66F62DF [eMMC] : FLASH_EXT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Brand : Lenovo ProdName : A2010-a ProdModel : Lenovo A2010-a Device : A2010-a AndroidVer: 5.1 MTKxCPU : MT6735M MTKxPRJ : A2010-a-t_USR_S233_1508012100_MP3V1_8G_ROW MediaTek MT67xx [x64] : Normalize settings Ok [Read Ok] : preloader_al712row.bin [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : logo.bin [Read Ok] : secro.img [Read Ok] : tz1.img [Read Ok] : tz2.img [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [ScatCFG] : MT6735M / V1.1.2 / al712row / EMMC FW Size : 2109 MiB Scatter saved to : C:\Users\AlijaanFactoryFile\Desktop\MT6735M__Lenov o__Lenovo_A2010-a__A2010-a__5.1__A2010-a-t_USR_S233_1508012100_MP3V1_8G_ROW\ All done! Done! Elapsed: 00:07:58 Reconnect Power/Cable! |
The Following 2 Users Say Thank You to alijaanfsd For This Useful Post: |
03-10-2016, 15:08 | #4 (permalink) |
No Life Poster Join Date: Apr 2014 Location: Charsadda kpk Age: 41
Member: 2166444 Status: Offline Thanks Meter: 298 | Lenovo A2010-a Read Flash Done by cm2 v- 1.41 Read v1.41 no error Operation : Check / Read Info [ v1.41 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 14 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 510001154D5332378D8E0042113BEFE0 Initialize Memory ... DRAM already initialized by Preloader eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMS27 [eMMC] : FLASH_CID : 150100513732534D42008E8DE0EF7211 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 77A7DDFAA69D389AC4959E1234E82B01 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : Lenovo ProdName : A2010-a ProdModel : Lenovo A2010-a Device : A2010-a AndroidVer: 5.1 MTKxCPU : MT6735M MTKxPRJ : A2010-a-t_USR_S256_1511241400_MP3V1_8G_ROW SECURITY : IMEI_SW [1] : 867203029922434 IMEI_SW [2] : 867203029988088 BTMAC Addr : A03299501542 WiFi MAC : A03299611542 MODEM : BaseBand : MT6735_S00_MOLY_LR9_W1444_MD_LWTG_MP_V8_P31_1_lwg_ n Done! all v 1.40 & 1.41 1.42-1.43 100% read done no error Unfortunately - not. Disable AV, install CM2 module, add it to exclude list ( whole folder ) and use. Some pity antivirus recognize service files as virus ( because they packed and protected ) I will not do anything for "solve" that. User can try use GOOD antivirus Last edited by GSM KPK; 03-10-2016 at 15:13. |
