Old 03-06-2016, 13:13   #1 (permalink)
rajufzr's Avatar
Member: 116314
Thanks Meter: 139
error making modem configuration file
der sir
error in making modem configuration file for mtk models
checked in 3 diifferent sets but failed
report for handset in hand is available
please check it for r&d purpose
Card found : S/N : D87EAC71 , v0130
Chinese Miracle II  [MTK module] v 1.42
Operation : Check / Read Info [ v1.42 ]
Wait for phone...
Phone found! [ 3 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BB_CPU_NME : [MediaTek] MT6572_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer   : 0x00FF
BLVersion : 0x0001
BootLdrSS : NORMAL with SPRELOADER
Processing DA stage
DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x88
NAND Flash : NOT INSTALLED
eMMC Flash : 1501004E35585A4D4201F931CEED2269
Initialize Memory ...
eMMC FlashIC initialized
[eMMC] : FLASH_INF : [SAMSUNG] , BMZX5
[eMMC] : FLASH_CID : 1501004E35585A4D4201F931CEED2269
[eMMC] : FLASH_LEN : 0x00000000E9000000
[eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB]
DEV RID    : CA6069CFA5CF35BFBDCB35171717CCBB
INT RAM    : 0x00020000
EXT RAM    : 0x20000000
BOOT TYPE  : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
[AP] : Initial info read Ok!
Brand     : GIONEE
ProdName  : GIONEE
ProdModel : P2S
Device    : GIONEE
AndroidVer: 4.2.2
MTKxCPU   : MT6572
MTKxPRJ   : ALPS.JB3.MP.V1
EXTRA :
LCD [0] : gn_tcl_hx8379a
LCD [1] : gn_truly_hx8379a
LCD Res : 800x480
TOUCH [0] : gn_gt968
CAM [0] : ov5645_mipi_yuv_af
CAM [1] : ov5645_ofilm_mipi_yuv_af
CAM [2] : gc0329_yuv
CAM [3] : hi704_yuv
MODEM : gionee72_wet_hspa_mp_hspa_ALL_RF_Config
LOCALE : en_US hi_IN pa_IN gu_IN bn_IN kn_IN ml_IN mr_IN ta_IN te_IN hdpi
Done!
Elapsed: 00:00:10
Reconnect Power/Cable!
Operation : Repair Security [ v1.42 ]
Wait for phone...
Phone found! [ 3 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Set IMEI [00] : 865032028582705
Set IMEI [01] : 865032029332704
Prepare finished. Security check required!
Wait for phone...
Phone found! [ 3 ]
Sync...
Device boot not done
Check Drivers
Try again
Error while post-checking procedure! Check drivers and battery charge!
In some cases - need reconnect mobile (just reinsert cable) on this step
Operation : Make BPLGUI Modem [ v1.42 ]
Wait for phone...
Phone found! [ 3 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Make modem configuration not possible for that phone :(
Done!
Elapsed: 00:00:10
Wait for phone...
Phone found! [ 3 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
DA Select done, will use MTK_AllInOne_DA_v3.3001.01.01
SOC VERIFY : C1
Boot Ok!
Done!
Elapsed: 00:00:11
Old 03-07-2016, 08:46   #2 (permalink)
rajufzr's Avatar
Member: 116314
Thanks Meter: 139
Any guidence from team?
Old 03-07-2016, 09:15   #3 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 16,000
Hello.
There is possible 2 things :
Phone not store that Config inside or it in another format.
Make FW read and send me it for checking.
For second step on security repair - install cdc driver forcedly.
The Following User Says Thank You to JayDi For This Useful Post:
Old 03-07-2016, 10:06   #4 (permalink)
Member: 2399421
Thanks Meter: 154
hi
its can be solved by installing cdc driver forcedly
i had already same your problem so i installed driver....
and solved my problem
Old 03-10-2016, 15:19   #5 (permalink)
rajufzr's Avatar
Member: 116314
Thanks Meter: 139
thanx solved by driver mantenance
now modem configuration works ok
first i checked this is fresh installed pc
Page generated in 0.30317 seconds with 7 queries
