03-18-2019, 15:41 | #1 (permalink) |
Junior Member Join Date: Dec 2016
Member: 2664735 Status: Offline Thanks Meter: 5 | error message cm2 dongle warning : dongle msconfigure ! . I contacted with supporting system and did all the steps through this link https://www.infinity-box.com/support/?r=4 but it stills give the error message . please help me to fix it as soo as possible. Thanks . |
03-19-2019, 08:23 | #3 (permalink) | |
Member: 2664735 Status: Offline Thanks Meter: 5 | Quote:
Box/Dongle type selected: Infinity-Box/Dongle Card-Reader: Alcor Micro USB Smart Card Reader 0 HWID: 01097B8024881292 Box/Dongle found: Infinity-Box/Dongle Reading... Serial No (S/N): D0467B80 Firmware version: 0137.02 === Process started: 03/19/2019 10:52:31 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0031] Dongle identification data damaged. Contact to http://www.infinity-box.com/support/?r=2 | |
03-19-2019, 08:26 | #4 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Attach fault.bin file here (do not use external file sharing servers) or send e-mail with file and problem info to: help [at] infinity-box.com |
03-20-2019, 19:15 | #9 (permalink) |
Member: 2664735 Status: Offline Thanks Meter: 5 | === Process started: 03/20/2019 21:39:08 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication successfull Service stage 1 confirmed Securing session... Session secured ok Upgrading dongle... Wait 4-5 minutes ! DO NOT disconnect Box/Dongle ! Applet upgrade ok Checking Dongle Identification... Identification Ok. Finalizing... Finalizing ok Process completed === Process finished: 03/20/2019 21:39:54 === === DongleManager [Infinity] v1.72 [03/20/2019 21:39:54] === Box/Dongle type selected: Infinity-Box/Dongle Card-Reader: Alcor Micro USB Smart Card Reader 0 HWID: 01097B8024881292 Box/Dongle found: Infinity-Box/Dongle Serial No (S/N): D0467B80 Firmware version: 0137.02 => Activations: - 00: Infinity-Box/Dongle v.0137 Thanks . Solved my problem . |
03-24-2019, 07:46 | #11 (permalink) |
Member: 2664735 Status: Offline Thanks Meter: 5 | my problem back ! I upload download link fault.bin . http://Trainbit.com/files/6761133884/fault.bin error message is : Smart-Card msconfiguration! Contact to support ! error dongle manager is : === DongleManager [Infinity] v1.72 [03/24/2019 11:14:40] === Box/Dongle type selected: Infinity-Box/Dongle Card-Reader: Alcor Micro USB Smart Card Reader 0 HWID: 01097B8024881292 Box/Dongle found: Infinity-Box/Dongle Reading... Serial No (S/N): D0467B80 Firmware version: 0137.02 === Process started: 03/24/2019 11:14:41 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0031] Dongle identification data damaged. Contact to http://www.infinity-box.com/support/?r=2 |
03-24-2019, 14:39 | #13 (permalink) | |
03-24-2019, 16:25 | #15 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | There is a software conflict with this application: clevx usb monitor \appdata\local\temp\{438e237c-c9d2-4803-a1fe-ee77d929e548}\usblistener.exe you must uninstall it |
