08-10-2016, 11:34 | #1 (permalink) |
Freak Poster Join Date: Mar 2010 Location: {INDIA}
Member: 1272558 Status: Offline Sonork: 100.1669383 Thanks Meter: 317 | Orignal lg d686 read file & remove virus done by only cm2 { miracle box fail } ORIGNAL LG D686 READ FILE & REMOVE VIRUS DONE BY ONLY CM2 { MIRACLE BOX FAIL } Code: Start at : [8/9/2016 / 12:04:41 PM] Operation : Read Flash [ v1.54 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 97 ] Sync... Inital Boot Ok! BB_CPU_PID : 6575 BB_CPU_NME : [MediaTek] MT6575|MT6577_S00 BB_CPU_EXT : 0xCB00 , 0x8B00 , 0xE201 Processing BROM stage i2c Init : 0300771F SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x82 WD Disable stat : 0x0000 Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use SecMode DA Sending and initialize DA ... Running DA ver.3.2 on BBID : 0x84 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d2G8 [eMMC] : FLASH_CID : 90014A4838473264040307A3AA30A08B [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0xF9C96D9A9BF7D2B73BAF8567FD9887CC INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Content now ... Brand : lge ProdName : luv90ds_open_esa ProdModel : LG-D686 Device : luv90ds AndroidVer: 4.1.2 SWVersion : LGD686AT-00-V10b-ESA-XX-OCT-01-2013+0 CU_SWVer : D68610b-ESA-XX MTKxCPU : MT6577 MTKxPRJ : ALPS.JB.TC1.SP.V13 [Read Ok] : preloader_luv90ds_open_esa.bin [Read Ok] : DSP_BL [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : EBR2 [Read Ok] : EBR3 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : persist.img [Read Ok] : cust.img [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [ScatCFG] : MT6577 / V1.0.0 / luv90ds_open_esa / EMMC Android Info saved FW Size : 1383 MiB Scatter saved to : C:\Users\VASIM\Desktop\MT6577__lge__LG-D686__luv90ds__4.1.2__LGD686AT-00-V10b-ESA-XX-OCT-01-2013+0\ Start at : [8/9/2016 / 12:20:45 PM] Operation : Remove Viruses [SmartAV] [ v1.54 ] SmartAV Conf : 100/80/2000 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 95 ] Sync... Inital Boot Ok! BB_CPU_PID : 6575 BB_CPU_NME : [MediaTek] MT6575|MT6577_S00 BB_CPU_EXT : 0xCB00 , 0x8B00 , 0xE201 Processing BROM stage i2c Init : 0300771F SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x82 WD Disable stat : 0x0000 Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use SecMode DA Sending and initialize DA ... Running DA ver.3.2 on BBID : 0x84 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d2G8 [eMMC] : FLASH_CID : 90014A4838473264040307A3AA30A08B [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0xF9C96D9A9BF7D2B73BAF8567FD9887CC INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! SmartAV Init Ok! Scanning FileSystem now , please wait Scan Done, infected files found : 47 Removing infected files and scripts ... SmartAV Report : Removed 47 infected files! Making additional operations ... Special Op #1 : Clear Recovery Data Ok! Special Op #2 : Clear UserData Ok! Done! Done! Elapsed: 00:01:26 Reconnect Power/Cable! Finish at : [8/9/2016 / 12:22:12 PM] |
The Following User Says Thank You to vasimsiyana For This Useful Post: |
08-10-2016, 17:17 | #2 (permalink) |
Insane Poster Join Date: Jan 2003 Location: Nessebar,Bulgaria Age: 47
Member: 20089 Status: Offline Thanks Meter: 4 | Can you share readed file because I try several firmware and the still stuck on recovery with dead android figure. |
The Following User Says Thank You to Velko_Laita For This Useful Post: |
08-11-2016, 03:09 | #3 (permalink) | |
No Life Poster Join Date: Nov 2008 Location: ĦĦInFiNiTy CM2 For EvER!!
Member: 901711 Status: Offline Sonork: 100.1606138 Thanks Meter: 427 | Quote:
We know that Only Cm2 clear malware apps perfectly!!!..... >>MaO<< | |
09-29-2016, 18:35 | #4 (permalink) |
No Life Poster Join Date: Dec 2004 Location: Algeria
Member: 96141 Status: Offline Thanks Meter: 200 | can i do the same thing with LG D618 ? i have viruses to remove, i tryed but can't connect it with cm2mtk, is it mtk phone ? thanks info with lgtool Code: Connect mode: Normal Info received Disconnected Connecting with D618 Connected Receiving phone info Getting phone info Model: D618 Platform: LG Qualcomm Software Platform: Android SDRAM Size: 1 GB NAND Flash Size: 8 GB CPU: MSM8226 Firmware Released: Apr 16 2014 10:37:28 Firmware Compiled: Apr 16 2014 10:37:28 Firmware Version: WX_PROJEd/M8626A-AAAANAZM-1.0.6033 IMEI: 352662-xx-xxxxxx-x br. |
11-23-2017, 07:08 | #5 (permalink) |
Junior Member Join Date: Feb 2009
Member: 981512 Status: Offline Sonork: kingkhan4u2 Thanks Meter: 0 | i had restart issue lg d686 i just full factory reset by cm2 phone succesfuly done Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital Boot Ok! BB_CPU_PID : 6575 BB_CPU_NME : [MediaTek] MT6575|MT6577_S00 BB_CPU_EXT : 0xCB00 , 0x8B00 , 0xE201 Processing BROM stage i2c Init : 0300771F SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x82 WD Disable stat : 0x0000 Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.3.2 on BBID : 0x84 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d2G8 [eMMC] : FLASH_CID : 90014A4838473264040301A5B4B6A08F [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0x28B21D6BAE48F8D10C6C2AA8013EAE07 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear RDP Clear Ok! Done! Elapsed: 00:00:28 Reconnect Power/Cable! |
