Old 09-29-2015, 18:52   #1 (permalink)
atou's Avatar
Member: 1388609
Sonork: atou
Thanks Meter: 135
error to read info and read code cpu SC7715
Card found: S/N : 7C446640 , v0129
Chinese Miracle II [SPD module] v 1.05
Operation : Check/Read Info [ v1.05 ]
1. Remove battery. Insert battery back
2. Press and hold 'VolumeUp' and 'VolumeDown' keys
3. Insert cable
==== Wait for phone...
Phone found! [ 32 ]
Port Opened
Sync...
Initial Boot Failed!
Reconnect Power/Cable!
Operation : Read PatternLock [ v1.05 ]
3. Insert cable
Device boot not done
Check Drivers
Try again
3. Insert cable
Phone found! [ 241 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending FDL
[Info] : If SW freeze here more, than 15 seconds - remove cable
FDL Ready!
Boot Ver : SC7715 Generic Loader NAND v1.0
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
Unknown structure detected! Check correct model selection!
Elapsed: 00:00:27
Old 09-29-2015, 18:59   #2 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 15,655
Because it is SC7715 eMMC.
Old 09-29-2015, 19:06   #3 (permalink)
atou's Avatar
Member: 1388609
Sonork: atou
Thanks Meter: 135
mr.JayDi
how can i do to remove google account
Old 09-29-2015, 19:09   #4 (permalink)
JayDi's Avatar
Member: 462970
Select SC7715 eMMC and do Format FS. Only that way for now.
Old 09-29-2015, 19:12   #5 (permalink)
atou's Avatar
Member: 1388609
Sonork: atou
Thanks Meter: 135
mr.JayDi
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Error Init FL mode!
Checking Structure ...
Unknown structure detected! Something went wrong
If phone work normally - check correct selection (Model,FlashType)!
Elapsed: 00:00:26
can t format
Old 09-29-2015, 21:11   #6 (permalink)
atou's Avatar
Member: 1388609
Sonork: atou
Thanks Meter: 135
i need answer plz infinity teams
Old 09-29-2015, 21:18   #7 (permalink)
VIJAY2U2's Avatar
Member: 1039903
Thanks Meter: 2,025
Select SC7715 emmc boot from the list
Then try to format All will be OK.
As ur logs say u trying only with SC7715 Nand boot
If not getting it in ur big brain just leave it
Sent from my InFocus M350 using Tapatalk
Old 12-14-2015, 07:28   #8 (permalink)
Member: 2474453
Thanks Meter: 6
Thumbs up please help me how to read pac file sc7715 with infinity cmt2
Phone found! [ 32 ]
Port Opened
Sync...
3. Insert cable
Check Drivers
Try again
3. Insert cable
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
Elapsed: 00:00:27
Report Post
Old 12-15-2015, 07:47   #9 (permalink)
JayDi's Avatar
Member: 462970
What if read one post before yours?
Old 12-31-2015, 10:02   #10 (permalink)
Member: 2132984
Sonork: https://www.facebook.com/
sir jaydi how can i back up my spd sc7715?this is the logs..
in NAND
in emmc
Page generated in 1.13555 seconds with 7 queries
