01-02-2008, 20:26 | #1 (permalink) |
Freak Poster Join Date: Apr 2004 Location: Made In Brazil
Member: 62561 Status: Offline Thanks Meter: 706 | Error reading FF from Xin Bao 2632 Dual SIM Action: Read Full Flash Code: COM8 [VCP9] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection active Action: read NOR flash Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6205:8B00]... boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 01227E22022201:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #01 in region #00... flash: 01227E22022201:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #02 in region #00... flash: 01227E22022201:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #03 in region #00... flash: 01227E22022201:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud... 460800 Set baud Done Identification... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 01227E22022201:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb detecting chip #01 in region #00... flash: 01227E22022201:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 00800000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw1: VIGOR_PCB01_GSM_MT6205B_DN.6205_DOUBLE.BIN ver. sw2: VIGOR.6205.DOUBLE ffs offset/size: 003C0000/00040000 detect device identification#2... detection phase #1... . warning: optional information not found detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 003C0000 flash: 01227E22022201:18E59F00000000 checking area[00000000]: 00000000-007FFFFF... eeprom/ffs found near: 003C0000 detecting eeprom/ffs size... eeprom/ffs size: 00440000 ffs chip: 00 eeprom/ffs area: 00000000:003C0000-007FFFFF reading [flash[VIGOR_PCB01_GSM_MT6205B_DN.6205_DOUBLE.BIN]]... file saved: C:\Arquivos de programas\InfinityBox\ChineseMiracle\backup_flash[VIGOR_PCB01_GSM_MT6205B_DN.6205_DOUBLE.BIN]_20080102-155739.B0M.bin Finished, time used: 381 sec Remove/Install battery now ! - In phoneīs menu, i have only English and Chinese LP options. But, after open this file with LP Edit, i have this: - When i try to edit any LP, i have this result: Here is the readed FF file: VIGOR_PCB01_GSM_MT6205B_DN.6205_DOUBLE.BIN Somebody knows whatīs happening? b.r. Cryspim |
01-02-2008, 21:08 | #2 (permalink) |
Member: 62561 Status: Offline Thanks Meter: 706 | And, under the label, i have this pins: What is 6205-ON pin? Used only TX, RX and GND for flash reading. B.r. Cryspim Last edited by Cryspim; 01-02-2008 at 21:14. Reason: Picture Correction |
01-03-2008, 03:46 | #4 (permalink) |
Member: 62561 Status: Offline Thanks Meter: 706 | Thanks to answering. I think that i will wait for Infinity new hardware to autodetect pinouts, because my connector donīt have all pins inside. So, it would be a hard work changing pins positions. At this time, i have 6 different models of dual sim (2-sim) phones waiting for pinouts autofinder to read/translate sw... When new hardware be ready, my work gonna fastly! b.r. Cryspim p.s: even with 2 cpu inside, this phone have only one IMEI number. I have another models that when pressed *#06#, displays primary and secondary IMEI. But some another models, even having 2 cpu inside (both sim are online at the same time) have only one IMEI number. Is it possible 2 cpu using just one IMEI? Last edited by Cryspim; 01-03-2008 at 03:53. Reason: increase question |
01-03-2008, 11:57 | #5 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! sometimes second imei is not shown when it is corrupted. but as i undrtoode- your phone is good working Some phones have 2 SIM cards, but in fact they work only with one card at the time. in this case phone is double sim, but phone is One MCU model |
01-03-2008, 20:58 | #6 (permalink) |
Member: 62561 Status: Offline Thanks Meter: 706 | Yes, my phone is fully working. And, removing all stick, i could see pinout for first CPU and solve my problem! Files are posted HERE. Sorry for previous fault. About IMEI question, i donīt have a good camera to take shots now, but see: Phone Model: Xin Bao 2632 Double SIM Card - This phone have double CPU. Without switching the phone off, it allows to use 2 different SIM cards to standby, but only one call can be received each time. As you can see above, TIM and Oi providers are both on line at the same time: But, when *#06# is typed, phone shows only ONE IMEI number. Second IMEI are not corrupted. It does not appears on screen: Phone Model: CECT 8899 Double SIM Card - This phone have double CPU. Without switching the phone off, it allows to use 2 different SIM cards to standby, but only one call can be received each time. As you can see above, TIM and Oi providers are both on line at the same time: When typed *#06#, phone shows 2 IMEI. Note that 2nd IMEI is corrupted (135790246811220), but phone is working well: So, my question is: itīs possible that even with 2 SIM online at the same time, phoneīs uses only ONE IMEI number for both lines? b.r. Cryspim |
Xin Tai T800i Dual SIM Card Phone with TV & Bluetooth - Gray | IPMART | ipmart WebShop | 0 | 05-08-2009 01:50 |
Xin Tai T1000i Dual SIM Card Phone With TV & Bluetooth | IPMART | ipmart WebShop | 0 | 04-28-2009 12:10 |
Xin Tai T800i Dual SIM Card Phone with TV & Bluetooth - Silver | IPMART | ipmart WebShop | 0 | 04-23-2009 08:50 |
Xin Tai T800i Dual SIM Card Phone with TV & Bluetooth - 1 GB | IPMART | ipmart WebShop | 0 | 04-03-2009 12:10 |
Xin Tai T900i Dual SIM Card Phone With TV & Bluetooth Function | IPMART | ipmart WebShop | 0 | 10-18-2008 11:20 |
