Old 05-19-2015, 00:00   #1 (permalink)
John(LMT)'s Avatar
Member: 507536
Thanks Meter: 75
Post Error Reading Flash MTK 6582
Hello Infinity Team i would like to know what means this error reading this flash in Factory Format.-
Chinese Miracle II  [MTK module] v 1.21
Operation : Read Flash [ v1.21 ]
Wait for phone...
Phone found! [ 100 ]
Sync...
Inital regs read done
Boot Info :
BB_CPU_ID : 6582
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0001
BB_CPU_NM : [MediaTek] MT6582_S00
Processing BROM stage
SecCfgVal : 0x00000000
BromVersion : 0xFF
BLVersion : 0x01
Preloader Status : Alive
Processing DA stage
DA Select done , sending
NAND_ID : 00000000000000000000000000000000
eMMC_ID : FE014E5030585858581000980D42302B
DA Stat : v4.2 on BBID : 0x87
DA Sent. Configure setting now ...
DA started successuflly
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 00FE , OEM : 014E
[eMMC] : FLASH_INF : XXXX0
[eMMC] : FLASH_CID : FE014E5030585858581000980D42302B
[eMMC] : FLASH_LEN : 0x00000000E9000000
INT RAM    : 0x00020000
EXT RAM    : 0x40000000
BOOT TYPE  : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Reading Flash Conent now ...
Brand     : samsung
ProdName  : SM-G900
ProdModel : SM-G900
Device    : SM-G900
AndroidVer: 4.4.2
MTKxCPU   : MT6582
MTKxPRJ   : ALPS.JB5.MP.V1.13
[Read Ok] : preloader_zx82.bin
[Read Ok] : MBR
[Read Ok] : EBR1
[Read Ok] : lk.bin
[Read Ok] : boot.img
[Read Ok] : recovery.img
[Read Ok] : secro.img
[Read Ok] : logo.bin
[Read Ok] : EBR2
[Read Ok] : system.img
[Read Ok] : cache.img
[Read Ok] : userdata.img
[Read Error] : Bad FAT/SD data
Looks like unusable file , break!
Read Ok , collect info
Brand     : samsung
ProdName  : SM-G900
ProdModel : SM-G900
Device    : SM-G900
AndroidVer: 4.4.2
MTKxCPU   : MT6582
File conversion error, file already exists! Saved as default!
Done!
Elapsed: 00:05:50
Reconnect Power/Cable!
Thanks in advance!
Old 05-19-2015, 04:39   #2 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
Hello, that error mean problem with FAT/SD partition.
Phone work fine? Internal storage show correct size/acessible?
Old 05-19-2015, 04:48   #3 (permalink)
John(LMT)'s Avatar
Member: 507536
Thanks Meter: 75
The problem with this phone is that i have to full wipe from recovery to make possible to system boot up, is there any solution for this? or it is hardware problem?
Old 05-19-2015, 04:54   #4 (permalink)
JayDi's Avatar
Member: 462970
Make "Format FS" - UDA+Cache
After make Factory Rest from settings menu in phone. After it should fix all info about partitions.
Old 05-19-2015, 04:55   #5 (permalink)
John(LMT)'s Avatar
Member: 507536
Thanks Meter: 75
Ok tomorrow I will try + post result, thanks Mr. JayDi Infinity Genius
Old 05-19-2015, 07:32   #6 (permalink)
Member: 2095587
Thanks Meter: 36
I make Factory Rest same problem
Card found: S/N 17AC:0128
Operation : Check / Read Info [ v1.21 ]
Wait for phone...
Device boot not done
Check Drivers
Try again
Boot Error!
Operation Failed
Elapsed: 00:00:31
Wait for phone...
Phone found! [ 754 ]
Sync...
Boot Info :
BB_CPU_ID : 6582
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0001
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
eMMC_ID : 150100513758534142019532DEF942D9
[eMMC] : FLASH_VEN : 0015 , OEM : 0100
[eMMC] : FLASH_INF : BASX7
[eMMC] : FLASH_CID : 150100513758534142019532DEF942D9
[eMMC] : FLASH_LEN : 0x00000001D2000000
SOC VERIFY : C1
Boot Ok!
[AP] : Initial info read Ok!
Done!
Elapsed: 00:00:06
Wait for phone...
Sync...
Boot Info :
BB_CPU_ID : 6582
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0001
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Brand : samsung
ProdName : Galaxy S6
ProdModel : SM-G920F
Device : Galaxy S6
AndroidVer: 5.0
MTKxCPU : MT6582
MTKxPRJ : ALPS.L0.MP2.V1_CELL6582.WT.L_P7
[Read Ok] : preloader_cell6582_wt_l.bin
[Read Ok] : MBR
[Read Ok] : EBR1
[Read Ok] : lk.bin
[Read Error] : Bad EXT data
Brand : samsung
Device : Galaxy S6
AndroidVer: 5.0
MTKxCPU : MT6582
Done!
Elapsed: 00:05:02
Old 05-19-2015, 16:06   #7 (permalink)
JayDi's Avatar
Member: 462970
@hamim ctg , your one is stuck on logo seems. Right?
Old 05-20-2015, 20:56   #8 (permalink)
John(LMT)'s Avatar
Member: 507536
Thanks Meter: 75
Same Error after Format FS, UDA+Cache
After making this same error, i also made a full reset from phone's menu. Any other suggestion please???
Thanks in advance
Operation : Format FileSystem [ v1.21 ]
Wait for phone...
Sync...
Boot Info :
BB_CPU_ID : 6582
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0001
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Backup : Skipped by user request
FMT Mode set to : 2
Format : Cache and UserData (Full Factory Reset)
Format CACHE block
Format block Ok!
Format UDA block
Format block Ok!
Done!
Elapsed: 00:00:49
Old 05-21-2015, 06:17   #9 (permalink)
JayDi's Avatar
Member: 462970
I work now on repair for such cases.
Page generated in 0.22742 seconds with 8 queries
