10-09-2015, 19:20 | #1 (permalink) |
No Life Poster Join Date: May 2007 Location: "Alfa-Gsm"
Member: 507536 Status: Offline Thanks Meter: 75 | Error Reading Phonebook MT6582 Code: Operation : Read UserData [ v1.32 ] PhoneBook : Enabled 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 36 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 1501005137585341420160A0DE31C17D DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BASX7 [eMMC] : FLASH_CID : 1501005137585341420160A0DE31C17D [eMMC] : FLASH_EXT : 00400000/00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Step #1 |
10-13-2015, 18:04 | #7 (permalink) |
Member: 507536 Status: Offline Thanks Meter: 75 | Thanks for your fast reply, i have already made a full flash read in .ispff format, what do you suggest me to send it to you, because size of file readed is 7.28 GB edit: i will send you a pm of the readed flash file link in a moment mate. Last edited by John(LMT); 10-13-2015 at 18:13. |
10-17-2015, 15:31 | #10 (permalink) |
Member: 507536 Status: Offline Thanks Meter: 75 | Phone Book Extraction Here is the new error shown with latest CM2MTK version, please i need your help team, i have already sent you the full dump via pm: |
