06-16-2009, 13:27 | #4 (permalink) |
Freak Poster Join Date: May 2008
Member: 783324 Status: Offline Thanks Meter: 15 | problem solved without infinity box.......... my phone is alive and support flash files can not help ........ here you find flasher and flash file you will find in sarunasoftware com http://rapidshare.com/files/24515647...nter_.rar.html |
03-11-2010, 13:43 | #5 (permalink) |
Junior Member Join Date: Dec 2009
Member: 1192015 Status: Offline Thanks Meter: 2 | lgkp320 flash error COM4 [VCP1] selected module v3.10 Device: Autodetect 6228-6239 NAND Checking data, wait... Action: write flash NAND write: Firmware KP320-00-V10c-ARB-XX-JUN-24-2008_A7610_07A_PCB03_GPRS_MT6229_S02[1].7S7610SA00-002-R1C_En_Ru_Fr_Urdu_Farsi_Ar.B4M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs nfi area detection... external bootloader is not present bootloader version: A7610_07A_BOOTLOADER_V005_MT6229_7S7610SA00-002-R1C.bin nfi area detection finished: Ok interface: BROM_DLL_v3.936.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6229:8A02:8A02 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0014]: 0098:00F100900095 [TOSHIBA] TC58NVG0S3AFT chip size: 128Mb page/spare size: 0800/0040 pages/block: 0040 bits i/o: 08 address cycles: 04 internal RAM size: 00020000 external RAM: absent done Set baudrate (921600)... done ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... detect sec ro... detect custom parameters... detect project-id... detect NAND info... number of areas to read: 1 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... warning: header is empty: probably flash chip completely erased warning: can not detect header nfi area detection finished: failed warning: ffs can not be detected TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done code offset: 00000000 ===> done nfi area detection... external bootloader is not present bootloader version: A7610_07A_BOOTLOADER_V005_MT6229_7S7610SA00-002-R1C.bin nfi area detection finished: Ok startup code area #1 check... startup code area #1 fixed number of cores: 3 loading files... number of areas: 3 done write... error: can not write flash: 0BC0:S_DA_DEVICE_NOT_FOUND error: last error: 0BC0:S_DA_DEVICE_NOT_FOUND Disconnect... done Finished, time used: 52 sec Remove/Install battery now ! plz help |
03-17-2010, 12:53 | #8 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | |
LG kp320 power on phone still kp320......... | kashi4lucky | Infinity-Box | 4 | 06-02-2009 07:33 |
LG KP320 lock code can this be supported? | shawgsm | Infinity-Box | 38 | 01-19-2009 08:56 |
LG kp320 lock Code | unlock trigger | VygisToolbox | 6 | 01-03-2009 14:44 |
[Request]Drivers & PCSuite for LG KP320 ! | PkM37 | LG | 2 | 12-11-2008 02:44 |
hi ,kp320 user code | gujjar_brothers | LG | 1 | 09-13-2008 00:45 |
