01-27-2016, 15:43 | #1 (permalink) |
No Life Poster Join Date: Dec 2006 Location: BEST COUNTRY
Member: 421947 Status: Offline Sonork: 100:1658491 Thanks Meter: 239 | error red sw Operation : Read Flash [ v1.40 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 90 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6795 BB_CPU_HW : CA00 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] Helio[X10]|MT6795_S00 Processing BROM stage SecCfgVal : 0x07000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 Error : DA init Failed! Error code : 0x1 Boot Error! Operation Failed Elapsed: 00:00:09 Reconnect Power/Cable! |
01-27-2016, 17:30 | #4 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Time. How much - have no idea. I have some solution for Meizu, but can't release it yet due copypasters problem. |
The Following 3 Users Say Thank You to JayDi For This Useful Post: |
04-14-2016, 20:34 | #6 (permalink) |
Freak Poster Join Date: May 2015 Location: Algiers, Algeria
Member: 2399672 Status: Offline Thanks Meter: 187 | This phone comes with a secured baseband chip; if you use a tool such as Sp flash tool it would return 5000 error saying that you need to use an auth file to authorize flash process. You need to use a different flash which comes with the auth file included. Which seems not available for public as far as I know. I got a couple of dead Meizu Mx5 phone but still haven't figured a way out to fix em. |
