08-12-2009, 00:04 | #1 (permalink) |
No Life Poster Join Date: Apr 2005 Location: America
Member: 138781 Status: Offline Thanks Meter: 850 | New Mtk 6318 INFINITY-BOX NO SUPPORT image link info chip mt6318a -- http://www.4shared.com/file/12444938...38a6/6318.html |
08-26-2009, 23:14 | #4 (permalink) |
Member: 138781 Status: Offline Thanks Meter: 850 | after a month of trying I could find the solution of this phone. 1. the PinFinder pinout not detected correctly. 2. I found the pinout at the time, not working 100% 3. I made a combination between the pinout as the PinFinder and found that I had found and was able to correctly identify the pinout. through the month of exhaustive search of this phone, now in minutes they go up the flash and correct pinout. despues de un mes de estar probando pude encontrar la solucion de este telefono. 1. la pinfinder no detecta el pinout correctamente. 2. el pinout que yo encontre en su momento, no funcionaba al 100% 3. hice una combinación entre el pinout que encontro la pinfinder y el que yo habia encontrado y pude detectar el pinout correctamente. gracias al mes de busqueda exhaustiva de este telefono, ahora en unos minuticos les subo la flash y el pinout correcto. |
08-27-2009, 00:02 | #5 (permalink) |
Member: 138781 Status: Offline Thanks Meter: 850 | I leave here the pinout and fullflash + eeprom ------> http://cellcarcol.forumcommunity.net/?t=30847610 Last edited by cellcarcol; 08-27-2009 at 00:08. |
08-28-2009, 23:35 | #7 (permalink) |
No Life Poster Join Date: Jan 2006 Location: Mirpur-1, Dhaka,Bangladesh
Member: 222009 Status: Offline Sonork: 100.1576751 Thanks Meter: 435 | r u sure its MT6318 cpu as u detect the pinout then pls post the full log of reading of formating with infinity or other tool .... it will be more clear about that new !!! phone |
08-29-2009, 03:07 | #8 (permalink) | |
Member: 138781 Status: Offline Thanks Meter: 850 | Quote:
mt6225 phone has the chip, which was correctly detected and repaired pinout tapeworm problems ... ... calibration and two bad imei. | |
08-29-2009, 20:06 | #9 (permalink) | |
Member: 222009 Status: Offline Sonork: 100.1576751 Thanks Meter: 435 | Quote:
need to mention only cpu and flasher for flashing phone ... (no need to see power/charging/sim ic) | |
08-29-2009, 20:14 | #10 (permalink) | ||
No Life Poster Join Date: Jul 2005 Location: player /-GSM-\ Field
Member: 161115 Status: Offline Sonork: Here you can find it... Thanks Meter: 3,039 | Quote:
power/ charging/sim/mmc | ||
new mtk-flash_tool.v-5.0and spiderman 2.30 | gopalhot | Chinese Models & Cloned Phones | 8 | 06-16-2008 10:24 |
20-03-2007 New MTK Tool update. More than 80% of chinese phones can be supported now! | GSMtricks | Multi-Box | 31 | 10-04-2007 12:23 |
when relese the new MTK | kalpeshoza | Multi-Box | 5 | 09-28-2007 06:48 |
06-08-2007 New update again! 3 new models added! NEW MTK Tool v.3.8! | GSMtricks | Multi-Box | 16 | 08-20-2007 20:11 |
23-02-2007 New Philips Tool and New MTK Tool - 2 new models added! | GSMtricks | Multi-Box | 18 | 02-24-2007 12:22 |
