Error repair imei LG A290 After format all imei is : 35030526000000 I select MT6253, in model lg A290 no have option for 3 imei I repair imei 1 and 2 perfect but imei 3 no repair COM4 [VCP2] selected module v4.36 Device: _Autodetect MT6250-6253 etc. Checking data, wait... Operation: write 351610058389512 mode-2 META imei #3 for triple sim CPU interface: META_DLL_v6.1108.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... done Release Power button now ! BaseBand chip version: MT6253, E02 ECO version: DSP firmware version: 2000.00.00 DSP patch version: 1.0 S/W version: MAUI.10AW1108A2SP.W11.41 H/W board version: LGE_A2_HW Melody version Melody V0.0 Version: MAUI.10AW1108A2SP.W11.41 detecting structure imei... error: detection failed (21 tries) error: can not read original imei #3, operation aborted Shutdown... done Finished, time used: 33 sec Remove/Install battery now ! COM4 [VCP2] selected module v4.36 Device: _Autodetect MT6250-6253 etc. Checking data, wait... advanced flash detection disabled Action: "repair imei" imei write method: mode-3 flash imei write channel: imei #3 for triple sim CPU new imei: 351610058389512 ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6253:8A02:8A00]... CPU: MT6253 high speed boot On chip: 0000:0000:000F status: FF boot packet size: 0400 Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" Boot Fail Finished, time used: 11 sec Remove/Install battery now ! I change for low bautrate: COM4 [VCP2] selected module v4.36 Device: _Autodetect MT6250-6253 etc. Checking data, wait... advanced flash detection disabled Action: "repair imei" imei write method: mode-3 flash imei write channel: imei #3 for triple sim CPU new imei: 351610058389512 ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6253:8A02:8A00]... CPU: MT6253 high speed boot On chip: 0000:0000:000F status: FF boot packet size: 0400 Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" Boot Fail Finished, time used: 12 sec Remove/Install battery now ! |
Infinity support is there? Does this error may occur you? I start to regret buying an additional year of support ...... But you really were the best, good rest! |
Thank you for you support infinity team |
Support no more good, thanks for you help team infinity |
I'm wait support, thanks |
Waiting for your results. |
LG A290 no have repair 3 imei, only one imei, bug? Repair only first imei thanks for you support, I need repair imei 3, I repair 1 and 2 imei with mtk |
We will double check software ASAP. |
I am also same problem with our turca friends. |
I hope still in infity or otherwise paid for nothing a year of support |
Does this updating will take? |
