09-20-2015, 16:17 | #1 (permalink) |
No Life Poster Join Date: Jan 2011 Location: algeria
Member: 1503017 Status: Offline Thanks Meter: 447 | error reset orro g20 i try many times to reset gmail from orro g20 - spd- but always error ...!!!!! Code: Operation : Format File System [ v1.05 ] Settings : SmartFormat is On 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 87 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending boot ... Boot Sent , starting... Boot didn't start! Check model selection! Boot Error! Break Reconnect Power/Cable! |
09-20-2015, 18:01 | #2 (permalink) |
No Life Poster Join Date: Apr 2009 Location: Inside Infinity
Member: 1010626 Status: Offline Sonork: using fb Thanks Meter: 735 | Hello Plz select one by one cpu boot and then read info if u get read info completely then u can format r read pattern and check which cpu inside Sent from my GiONEE S7 using Tapatalk |
The Following User Says Thank You to princesaddam For This Useful Post: |
01-19-2016, 18:28 | #6 (permalink) |
No Life Poster Join Date: Jan 2006 Location: Santiago de Cuba Age: 46
Member: 220595 Status: Offline Thanks Meter: 355 | I tested connecting this phone using the flash file at needrom and cm2spd and I could not connect to it. am afradi to flash it using stock spd flasher and kill it. |
01-19-2016, 21:20 | #7 (permalink) |
Member: 1010626 Status: Offline Sonork: using fb Thanks Meter: 735 | If u have rom just select last boot and select firmware then read info and format in cm2 ur mble will work like charm Sent from my S_plus using Tapatalk |
