Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Dec 2004 Location: Egypt Age: 35
Member: 99784 Status: Offline Thanks: 15
| error unloking LGke970 this is the log can some one tell me what's wrong COM21 [VCP0] selected Device: LG-KE970 Checking data, wait... Action: reset Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... next part... boot answer: 00 error: unknown bootcode answer: Release Power button now Boot Failed Finished, Remove/Install battery now ! Time used: 15 sec |
| | #2 (permalink) |
| problem solved I use pinfinder in the first time but now I use LGkg300 cable and now all fine thanks infinity team br GalaxyMan COM21 [VCP0] selected Device: LG-KE970 Checking data, wait... Action: unlock direct unlock Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud... 460800 Set Baud Done Connecting... flash: 0089:88B0 Connecting Done Check hardware... Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\LG-KE970_eeprom-sta_20080728-221702.B1E.bin reading [eeprom-sta2]... file saved: C:\Program Files\InfinityBox\Pana01\LG-KE970_eeprom-sta2_20080728-221704.B1E.bin loading data... data loaded imei: 35030526000000100 reading [eeprom-sec_35030526000000100]... file saved: C:\Program Files\InfinityBox\Pana01\LG-KE970_eeprom-sec_35030526000000100_20080728-221706.B1E.bin reading [eeprom-complete_35030526000000100]... file saved: C:\Program Files\InfinityBox\Pana01\LG-KE970_eeprom-complete_35030526000000100_20080728-221708.B1E.bin backup critical area Done Check memory... Check memory Done Write... Erasing: eeprom-complete Writing: eeprom-complete Verifying... Verify result: 011B Done probably you need to restore original imei after unlock process Write Done Finished, Remove/Install battery now ! Time used: 39 sec |
| | #3 (permalink) |
| Product Manager ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2005 Location: infinity-box
Member: 130995 Status: Offline Thanks: 9,039
| Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems and successfully done work. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Error Unloking Zv40 | GSMSERVE | UST Pro II | 7 | 09-09-2010 00:36 |
| Error unlok j132 | adelgsm | Cruiser Suite | 1 | 01-21-2009 11:10 |
| Protocol error unloking HUAWEI E272 | ALB-ARM | KULANKENDI Server | 3 | 07-15-2008 07:05 |
| blackberry 7100g error unloking with fg! plz help | ABDELFATTAH NET | FuriouS TeaM Products | 2 | 05-26-2008 23:10 |
| error unloking 6300!!!! | Byte | J.A.F. Plus | 3 | 05-05-2008 03:52 |
