11-25-2010, 19:45 | #1 (permalink) |
No Life Poster Join Date: May 2010 Location: In The World
Member: 1294926 Status: Offline Sonork: 100.1608183 Thanks Meter: 126 | error when trying flash kp320 Code: COM3 [VCP0] selected module v3.63 Device: LG-KP320 Checking data, wait... Action: write flash NAND write: Firmware KP320-00-V10c-ARB-XX-JUN-24-2008_A7610_07A_PCB03_GPRS_MT6229_S02.7S7610SA00-002-R1C_En_Ru_Fr_Urdu_Farsi_Ar.B4M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs nfi area detection... external bootloader is not present bootloader version: A7610_07A_BOOTLOADER_V005_MT6229_7S7610SA00-002-R1C.bin nfi area detection (3 cores) finished: Ok "format ffs" active interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6229:8A02:8A02 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0014]: 0098:00F100900095 [TOSHIBA] TC58NVG0S3AFT chip size: 128Mb page/spare size: 0800/0040 pages per block: 0040 bits i/o: 08 address cycles: 04 internal RAM size: 00020000 external RAM: S_DA_RAM_ERROR done Set baudrate (921600)... done ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 02000000/06000000 firmware size: 32Mb ffs size: 96Mb detect sec ro... detect custom parameters... detect project-id... project-id: 7S7610SA00-002-R1C detect NAND info... number of areas/bytes to read: 1:00080000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... external bootloader is not present bootloader version: A7610_07A_BOOTLOADER_V005_MT6229_7S7610SA00-002-R1C.bin nfi area detection (3 cores) finished: Ok TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 04 sw version: A7610_07A_PCB03_GPRS_MT6229_S02.7S7610SA00-002-R1C.BIN project-id: 7S7610SA00-002-R1C, 00000000 code offset: 00000000 ffs offset/size [01]: 02000000/06000000 rom info structure: [standard] type (04) TCL-ID is absent ===> done nfi area detection... external bootloader is not present bootloader version: A7610_07A_BOOTLOADER_V005_MT6229_7S7610SA00-002-R1C.bin nfi area detection (3 cores) finished: Ok startup code area #1 check... done number of cores: 3 loading files... number of areas: 3 done write... write bootloader... . write core... error: can not write flash: 0BEA:S_DA_NFB_BOOTLOADER_NOT_EXIST error: last error: 0BEA:S_DA_NFB_BOOTLOADER_NOT_EXIST Disconnect... done Finished, time used: 42 sec Remove/Install battery now ! |
11-25-2010, 20:03 | #2 (permalink) | |
No Life Poster Join Date: Apr 2005 Location: John Kemeny1926-1992 Age: 57
Member: 136220 Status: Offline Thanks Meter: 407 | Quote:
flash free MultiGSM_V21.exe +finware KP320-00-V10g-CIS-XX-APR-17-2009_A7610_07A_PCB03_GPRS_MT6229_S02.7S7610RU00-001-R1Z_En_Ru_Kz_Ua.B4M.bin cable com unversial teste100/100 search forum | |
11-27-2010, 14:12 | #3 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | @i-touch Try to flash phone with another flash file. What is the results ? |
11-29-2010, 00:52 | #5 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | What is the problem with phone ? Is it was good working phone or dead phone ? |
11-29-2010, 14:24 | #7 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Try to make "format whole flash chip" operation. Try to flash phone again. If problem still exist I think you have a reason to check phone hardware. |
need to flash 6110 | paulomt1 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 08-16-2019 19:37 |
5110 flash new software , need help | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 01-03-2015 05:41 |
where to find a working program all they have some errors ?? | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 12-12-2012 13:26 |
error (1002) simlock3.dll winopen | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 08-28-1999 15:57 |
