02-23-2010, 06:58 | #1 (permalink) |
No Life Poster Join Date: Apr 2008 Location: PROTECTED BY 308
Member: 750001 Status: Offline Sonork: 100.1641021 Thanks Meter: 1,269 | error while reapairing IMEI INFENION CHIP 7880 here log n flash file Flash file link http://www.4shared.com/file/22790534..._7880_B1X.html n i selected model to change imei Digibee-BSNL-G200CF COM3 [VCP0] selected module v1.60 Device: Digibee-BSNL-G200CF Checking data, wait... Action: "repair imei" new imei: 351847003536777 Boot ... Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... sw version: .00 ULC2GL 0 A 0 q Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Digibee-BSNL-G200CF_eeprom-static_20100223-111747.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Digibee-BSNL-G200CF_eeprom-security_20100223-111748.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Digibee-BSNL-G200CF_eeprom-complete_20100223-111755.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\Digibee-BSNL-G200CF_imei-area_20100223-111814.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\Digibee-BSNL-G200CF_lock-area_20100223-111827.B1E.bin backup critical area Done Check memory ... lock found error: unknown firmware, read flash and send to support Check memory Failed Finished, time used: 57 sec Remove/Install battery now ! Finished |
02-23-2010, 07:45 | #3 (permalink) |
Member: 750001 Status: Offline Sonork: 100.1641021 Thanks Meter: 1,269 | error: unknown firmware, read flash and send to support COM3 [VCP0] selected module v1.76 Device: Ajanta-A1800 Checking data, wait... Action: "repair imei" new imei: 358280017067998 Boot ... Press and HOLD Power button now ! e-gold: 820000 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... Check hardware Done Check parameters ... sw version: .00 ULC2GL 0 A 0 q Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Ajanta-A1800_eeprom-static_20100223-121407.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Ajanta-A1800_eeprom-security_20100223-121408.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Ajanta-A1800_eeprom-complete_20100223-121414.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\Ajanta-A1800_imei-area_20100223-121441.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\Ajanta-A1800_lock-area_20100223-121526.B1E.bin backup critical area Done Check memory ... lock found lock type #1 found error: unknown firmware, read flash and send to support Check memory Failed Finished, time used: 1 min 40 sec Remove/Install battery now ! Finished |
How to change Imei for infenion chip, Geepee mobile | nakshatra | Chinese Models & Cloned Phones | 0 | 03-21-2010 05:35 |
How to change Imei for infenion chip, Geepee mobile | nakshatra | CPF-Dongle | 0 | 03-21-2010 05:31 |
Error while repairing imei by MX KEY | akashub | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 13 | 02-13-2010 09:05 |
error while rebuilding imei whats the problem | neeraj1st | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 0 | 12-23-2009 15:58 |
Infenion Chips Flashing Problem | Dilip_Nath | VE-PRO BOX | 0 | 12-27-2008 08:43 |
