01-07-2010, 15:25 | #1 (permalink) |
No Life Poster Join Date: Jan 2005 Location: United Kingdom
Member: 109729 Status: Offline Thanks Meter: 36 | Error on write imei on iphone 168C+ Action: imei Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... and don't pass to 4% on step 2 i have: Code: COM2 [VCP0] selected module v3.02 Action: imei imei write method: mode-2 imei write channel: imei #2 for dual sim/mono CPU new imei: 354969010737474 Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:5103:0004 status: FF Connecting at 19200, wait... warning: wrong packet cs Release Power button now ! Phone detected, wait... warning: wrong packet cs Hardware: ctprimitivewˆithnon-existeddestination(100). Date: Version: Version: Version: detecting structure #2... warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs 15 16 17 18 19 20 21 22 23 24 on mode 3 after back-up have error... tryed manny times with baudrate autoselect ,slow speed. etc.. |
01-08-2010, 08:23 | #4 (permalink) |
Member: 109729 Status: Offline Thanks Meter: 36 | like i say before Connecting, wait... and don't pass to 4% . I tryed method 3 and now phone is dead. I flashed phone with same version of sw KONKA25_GEMINI_07B_PCB01_GPRS_MT6225_S00.MAUI_07B_ W08_16_MP_V03__iFOE P168+_32m_En_Ru_Fr_Es_It_De_Ml_Id_Vn_Cn_Pt_Cn_Ar.B 0M.bin from support, and tryed again all 3 method at differed baudrate. finaly solved! Code: COM2 [VCP0] selected module v3.02 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: "repair imei" imei write method: mode-3 imei write channel: imei #2 for dual sim/mono CPU new imei: 354969010737474 ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! baud autodetection active 19200 autodetect Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:5103:0004 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:21131800000000 flash: Amd AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #02 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #03 in region #00... flash: 01227E22202200:21131800000000 flash: Amd AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 230400 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:21131800000000 flash: Amd AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #02 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 02/01 total flash region size: 02000000 .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is absent rom info detection finished rom info protocol ver: 04 ver. sw 1: KONKA25_GEMINI_07B_PCB01_GPRS_MT6225_S00.MAUI_07B_W08_16_MP_V03.BIN ver. sw 2: MAUI.07B.W08.16.MP.V03, 00000000 code offset: 00000000 ffs offset/size: 01E00000/00200000 detecting ffs/eeprom area in 2 chip(s)... standard ffs/eeprom offset detected: 01E00000 standard ffs/eeprom offset confirmed: 01E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 01 ffs/eeprom area: 01000000:00E00000-00FFFFFF detecting startup code area #2... ................................................................................................................................................................................................................................................................ startup code area #2 is absent sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: KONKA25_GEMINI_07B_PCB01_GPRS_MT6225_S00.MAUI_07B_W08_16_MP_V03__ffs... file saved: C:\Program Files\InfinityBox\ChineseMiracle\KONKA25_GEMINI_07B_PCB01_GPRS_MT6225_S00.MAUI_07B_W08_16_MP_V03__ffs_20100108-090413.B0E.bin flash: 01227E22202200:18E59F00000000 Backup required data Done ====> Patch required data ... 1 step(s) required Patch required data Done ====> Special operation ... Special operation Done ====> Write ... flash: 01227E22202200:21131800000000 Write: eeprom Write Done ====> Finalization ... Finalization Done Finished, time used: 368 sec Remove/Install battery now ! wbr and thank you for all replyes. |
write imei on b7610 error | jesyblue | Z3X-Team Products | 3 | 03-10-2010 20:29 |
samsung t809 is giving error in writing imei | gsmcrazy1 | NSPRO | 1 | 05-03-2009 10:14 |
lookin for some1 who can write imei on e770 | djstuh2006 | Wanted Products | 1 | 09-11-2006 19:09 |
Cant write imei on E310 | roniri | TST Dongle | 3 | 07-25-2005 06:01 |
Need help to write IMEI on GD90 | Drug_Store | Panasonic | 6 | 05-10-2003 23:54 |
