05-06-2005, 19:33 | #1 (permalink) |
No Life Poster Join Date: Nov 2004
Member: 91102 Status: Offline Thanks Meter: 34 | Error On X300 I HAVE TRIED TO UNLOCK A X300 AND THIS IS WHAT IGET COM14 ready Current device: X300 Checking data, wait... Boot... Press Power button now ! Connecting, wait... Err: wrong answer1: 6184 Boot Fail Finished Remove/Install battery now ! Time used: 6 sec Checking data, wait... Boot... Press Power button now ! Connecting, wait... Err: wrong answer1: 2449 Boot Fail Finished Remove/Install battery now ! Time used: 5 sec BR |
05-06-2005, 19:45 | #2 (permalink) |
Member: 91102 Status: Offline Thanks Meter: 34 | HI UNLOCKING PROBLEM IS SORTED BUT THE LANGUAGE IS CHANGED IN TO CHINEESE AND I DON'T UNDERSTAND A F************** WORD IS THERE A WAY TO SET BACK TO ENGLISH HERE IS WHAT HAPPENED Log opened: [06/05/2005] [19:34:33] App: C:\Documents and Settings\New User\Desktop\UNLOCKINGSOFTWARE\INFINTY\infinitybox \GD55_G5x_G70_A100_X300_v114\GD55_G5x_G70_A100_X30 0_v114.exe [Infinity Box] v.1.14ALoading, wait... S/N: xxxxxxx Wait... Current device: X300 Done Checking data, wait... Boot... Press Power button now ! Connecting, wait... Boot Done Parameters... Parameters Done Check Boot block... Check Boot block Done Check space... Check space Done Check Flash... FLASH: 98:0074 Check Flash Done Check parameters... Check parameters Done Erasing... Erasing Done Writing... Exiting... Writing Done Finished Remove/Install battery now ! Time used: 43 sec BR Last edited by chowdary; 05-07-2005 at 08:02. |
05-06-2005, 19:56 | #3 (permalink) |
Member: 91102 Status: Offline Thanks Meter: 34 | I THINK INFINITY TEAM SHOULD DO SOMETHING ABOUT IT ASAP. BECAUSE ALL I CAN SEE IS TWO LANGUAGES IN LANGUAGE SETTING NOT GOOD ATALL AND EACH TIME I DO THE DEFAULT SETTINGS, IT GOES TO CHINEESE OR WHATEVER DEFAULT LANGUAGE IS NEED AN URGENT SOLUTION BR |
05-06-2005, 20:16 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello ! TOP URGENT solution: flash phone with other (non Chinese) MAIN+LP+MAP flash files. Detailed description: 1. Chinese words is absolutely not F****** words, but really great and easy to understand words. Just need to get some knowledge in Chinese language and you will see how this language is beautiful. 2. If you need in phone other languages than Chinese, just flash phone (MAIN+LP+MAP) with other flash files (pls check Flash Files description from support area to select correct flash). 3. If you need Chinese language in X300 and you have flashed X300 with Chinese LP/MAP and then make "Reset defaults" then it's normal situation that you see Chinese language as a default language. This happen because each LP/MAP has "default language" settings inside it and this default language (in your case: Chinese) become active language after you reset phone settings to defaults. I think it will be very strange if Chinese people have to try to understand "strange English" words when they buy Chinese phone and make first Power-On try. So, please, use other flash files and you will be really satisfied with results. Waiting for your reply with results. B.R. InfinitySupport |
05-06-2005, 20:23 | #5 (permalink) |
Member: 91102 Status: Offline Thanks Meter: 34 | I Bought The Infinity Box To Unlock Not To Mess About With Languages And I Don't Think I Will Ever Unlock Another X300 With Infinty Box As It Messes The Whole Phone Up Or I Might Have To Hire A Translator To Put The Language Back To English What A Poor Solution For X300 It Means After Every Unlock I Got To Flash The Phone Too Bring It Back To Normal, Wow.. What A Great Solution |
05-06-2005, 20:48 | #6 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello ! If you want to get REALLY working phone after unlock it is need to make system reset. If you still have problems with Chinese language in menu after unlock, here is steps how to return English language after reset user settings: 1. Make unlock 2. Insert SIM card 3. Power-On phone, you will see message in Chinese. Phone ask you about PIN code. 4. Enter PIN code and press "#" key (to avoid troubles with Chinese language selection in menu "Ok/Cancel". 5. Wait until startup logo disappeared 6. Press left upper button once 7. Press left upper button once again 8. Press arrow down 3 (three) times 9. Press left upper button once 10. Press arrow down once 11. Press left upper button once 12. Press upper arrow button one or 2 times to move highlite to second row from up 13. Press left upper button once 14. Now you will see message "Language is set to: English" Also, every time when you flash/unlock/reset any phone (Panasonic, Motorola or any other brand) it's good idea to check what languages inside this phone and check steps to return language to English back (like you see above). B.R. InfinitySupport |
05-06-2005, 21:00 | #7 (permalink) |
Member: 91102 Status: Offline Thanks Meter: 34 | thanks for your reply anyway. i am just flashing it now, it is half way through now and i hope it will be ok. i hope that i am not going to end up with a dead phone. it was a good explanation, but do i also have to explain to customers when i unlock their phone? i don't think that they will like the idea of every time if they need to reset the phone it will be change into chineese , and this has putt me off from x300 unlock with infinity, and i don't want to sit half of an hour after unlock to flash it br |
05-06-2005, 21:19 | #8 (permalink) | |
There are several ways to solve this problem: 1. Make unlock, then make (even with closed eyes possible) steps that we described above (go to menu and select English language). 2. In next software release we can remove "Reset defaults" option during unlock, but who know what customers say to you after this "improvement". HINT: Our programmers has many years (really, many years, not months or days) experience in mobile-phones technology and they know what to do to get good results. If they think that it is better to make "system reset" after unlock this means that it will be good for your phone (and finally for your future relation with your satisfied customers) to make this thing. Also, I think that it's not so big price for really-working-phone-after-unlock: press several buttons on phone with closed eyes to return language back to English. 3. Flash phone with language set for your region. In this case you will get after flashing clear phone, w/o any Chinese customization. B.R. InfinitySupport | |
05-06-2005, 21:58 | #10 (permalink) |
Member: 91102 Status: Offline Thanks Meter: 34 | hi like u said that in next update u will remove that system reset option. i hope that will solve the problem there wouldn't be any problem if it doesn't set chineese as default language and customers can't even notice then but every time if they reset the phone and language goe in chineese then they will be nocking on my door and i will be nocking on your door THERE IS NO DOUBT, I LOVE MY INFINITY BOX JUST FOR SIMPLE FACT THAT IT DOES X70'S AND NEC101 but i will be glad if x300 problems gets sorted thanks for your support anyway AND ALSO U ARE THE ONLY FASTEST REPLYER IN THIS FORUM BR |
05-06-2005, 23:27 | #11 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello ! Really, I have to be very patient. And today I was... Also, I really respect all Infinity-Box users, not depends on their mobile-unlocking experience. Also, in future I'll make all that depends on me to help other people to solve their problems with Infinity-Box. Also, from my side, I want to ask Infinity-Box users to respect big experience and knowledges of our programmers. And for sure, if we say "this will be better for your phone" you can beleive us: it will be better. Also, about our software improvement (in x300 unlock): I sad only that "we can remove". This not means "will be removed for sure". Reason: I don't want that users knock to my (and yours too) door with words "what's happen with my lovely mobile, why it's so buggy after unlock". I tell again: it will be better for future stable and correct phone operation to MAKE system reset during unlock process. Small rule: Chinese phone have to have Chinese language by default. (c) Panasonic Mobile B.R. InfinitySupport P.S. Small story, for good dreams today: One man don't know any word in Chinese language, but he has mobile phone with Chinese language inside. He asked many mobile service centers over the World, but nobody can install into his phone rare MyLanguage. Then this man send letter to Panasonic Mobile and ask them: "What are you doing, dear friends ? Why you set Chinese language in Chinese phones by default ? Really, it's not good. Let's set MyLanguage by default (not depends on phone firmware and country) and all MyLanguage-speaking people will be happy, but rest people... maybe they will be happy too and they can study some new words in MyLanguage too." Several days after this, he received reply from this famous company (they really respect his customers): "Yea... we will make this changes in nearest YourPhone firmware release with big pleasure. Because Chinese people must learn MyLanguage ! And for all European firmwares we will make Chinese language by default, to give our European friends possibility to study Chinese a bit ! World is so big, so let's Chinese people speak English, Europeans let's speak Chinese, and we (famous Panasonic company) will make our best to make people more close each other. So, let's World will be one for all ! Peace for all !" |
05-07-2005, 08:08 | #12 (permalink) |
Member: 91102 Status: Offline Thanks Meter: 34 | oh by the way i was talking about UK TMOBILE X300 NOT A CHINEESE X300 and the default language was english not chineese my friend any way problem sorted after flashing i will try one x300 and i will see how it goes br |
05-07-2005, 09:23 | #13 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello ! Really, glad to hear that problem sorted. Also, if you will be near UK TMOBILE office (no need to go there especially to do that, but if you will have free time...), just open the door and say "Hello, my dear Chinese partners !". Im sure they will be glad to hear something like this. If they sell in UK mobiles with Chinese language inside then I can imagine only 3 things: 1. They are Chinese people 2. They are very smart people and they can speak Chinese much better than I can speak English. 3. They are so lazy (or maybe busy) and they don't have enough time to install European language set in his mobiles. In first 2 cases - my big respect to UK TMOBILE Team ! In last case: you can offer them several Infinity-Box sets by reasonable price and Im sure you can get good profit by this deal. B.R. InfinitySupport |
11-05-2006, 16:28 | #14 (permalink) |
No Life Poster Join Date: Mar 2006 Location: Philippines
Member: 252201 Status: Offline Thanks Meter: 148 | I also experienced the same problem when i reset the phone because it displayed panasonic hang. Cannot be fixed with codes. So i try resetting. It done succesfully but the languange turned into chinese. What i did was a trial and error method. Just recalling the logo on the phone setting because it cant be change irrespective of language. After a more than 30 minutes, i did it. Is there any a direct code to return to english lang just like with lg ang alcatel aside from the mentioned by the infinity support? |
11-05-2006, 21:53 | #15 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hi, I am not sure but you can try: *#0000# *#0044# also, you can write non-Chinese MAP file in phone and make reset again. After this operation phone default language must be the same as in MAP file was set by default. |
X300 error on flashing | FMC_GSM | Panasonic | 4 | 01-12-2007 21:32 |
X300 error on flashing | FMC_GSM | Infinity-Box | 2 | 11-12-2006 02:49 |
Error, Error on my box.. Wat going on? | alex12345 | Universalbox | 5 | 04-16-2006 10:53 |
Unlock x300 using PanaUFO Cracked - error on 25% | kades | Panasonic | 5 | 08-08-2005 00:28 |
