08-13-2016, 16:00 | #1 (permalink) |
No Life Poster Join Date: Oct 2015 Location: Unknown
Member: 2469611 Status: Offline Thanks Meter: 389 | Eurostar Epad 2 RK 2928 All Operations Done Code: Connect device to PC! Hold 'VolUp'+'VolDown' or 'VolUp', insert USB cable, press 'PowerOn'! Found active FlashInterface , connecting ... Detected : RK2928 Read Info Ok! Operation : ReadInfo [ v1.0 ] ======= Flash Info : Channel : 0x00 FlashType : ADD7949160 FlashSize : 0x0000000100000000 FlashCaps : 2097152/8192/42/40/2 ======= Device Info : CPU : RK2928 Android : v4.1.1 Project : 20131226.103448 Name : rk2928sdk Brand : EUROSTAR Device : rk2928sdk Model : ET7006C-B13 Read Info Ok! Elapsed: 00:00:05 Read Flash Code: Operation : Read Flash [ v1.0 ] Collect InitData ... Reading now ... Reading : PARAMS Reading : MISC Reading : KERNEL Reading : BOOT Reading : RECOVERY Reading : BACKUP Reading : CACHE Reading : USERDATA Reading : SYSTEM Read Ok! Firmware size : 550 MiB Saved as : RK2928__ET7006C-B13__rk2928sdk__20131226.103448.irkfw Done! Elapsed: 00:01:03 Factory Reset (Too Many Pattern Attempts Remove) Done Code: Connect device to PC! Hold 'VolUp'+'VolDown' or 'VolUp', insert USB cable, press 'PowerOn'! Found active FlashInterface , connecting ... Detected : RK2928 Read Info Ok! Format FS/Reset Settings accepted by User! Operation : FormatFS / ResetSettings [ v1.0 ] Init UserData Init Cache Init IntSD Init Ok! Format prepare Done! Wait, until device reboot Elapsed: 00:00:00 |
