10-04-2017, 16:38 | #2 (permalink) |
No Life Poster Join Date: Mar 2014 Location: Romania
Member: 2157664 Status: Offline Thanks Meter: 43 | ========================= Start ========================= 04.10.2017 / 18:10:54 ================================================== ======= Card found : S/N : xxxxxxxx , v0136 Chinese Miracle II [MTK module] v 1.58 Start at : [04.10.2017 / 18:11:14] Operation : SP Unlock [ v1.58 ] Mode : Direct Unlock 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 218 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 510001154D33313332EF064203238DC8 Initialize Memory ... DRAM configured from IDB! DRAM initialize passed! DRAM size : 0x80000000 DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM313 [eMMC] : FLASH_CID : 150100513331334D4206EF32C88D5303 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0xCA6E4BB7CF1B3D9B480BBC9588636DF5 INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! USBDL : Init HSUSB Ok SIM Lock Status : Locked! Unlocking now ... Error while unlocking, somethig went wrong! Operation Failed Elapsed: 00:00:30 Reconnect Power/Cable! Finish at : [04.10.2017 / 18:11:45] |
10-04-2017, 17:07 | #3 (permalink) |
Freak Poster Join Date: Feb 2006 Location: Narnia Age: 44
Member: 236667 Status: Offline Thanks Meter: 12 | I have the same model,and infinity cannot unlock them.With read code option reads a 8 digit code,and the phone asks 16 digit code.Some kind of specific perso.Mine is from ukraine. |
10-04-2017, 22:06 | #4 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,785 | After making nvram+nvdata backup, simply re-flash the phone, with appropriate ROM file. Post results. b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! |
10-05-2017, 07:47 | #5 (permalink) |
Member: 236667 Status: Offline Thanks Meter: 12 | I reflashed and it does the same.Infinity identifies wrong this platform: it says MT6737M,and the phone has MT6735.Thats why the algo cannot be analized corectly,hence the codes are wrong. Card found : S/N : 39ECF11F , v0136 Chinese Miracle II [MTK module] v 1.58 Operation : SP Unlock [ v1.58 ] Mode : Read Codes 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 45 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 460001154D323237425800426BA9A6C2 Initialize Memory ... DRAM configured from IDB! DRAM initialize passed! DRAM size : 0x40000000 DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM227 [eMMC] : FLASH_CID : 150100463732324D42005842C2A6936B [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0x41BAC50D5DCBB1AE5F554E17B1A72A71 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! USBDL : Init HSUSB Ok Slot[1] SIMLock Info : [1] Level , [Locked] : True , [Count] : 9 , [Spc] : 256 , [UnlockCode] : 53293457 [2] Level , [Locked] : False [3] Level , [Locked] : False [4] Level , [Locked] : False [5] Level , [Locked] : False [6] Level , [Locked] : False [7] Level , [Locked] : False Slot[2] SIMLock Info : [1] Level , [Locked] : False [2] Level , [Locked] : False [3] Level , [Locked] : False [4] Level , [Locked] : False [5] Level , [Locked] : False [6] Level , [Locked] : False [7] Level , [Locked] : False Done! Elapsed: 00:00:28 Reconnect Power/Cable! Operation : SP Unlock [ v1.58 ] Mode : Direct Unlock 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 45 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 460001154D323237425800426BA9A6C2 Initialize Memory ... DRAM configured from IDB! DRAM initialize passed! DRAM size : 0x40000000 DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM227 [eMMC] : FLASH_CID : 150100463732324D42005842C2A6936B [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0x41BAC50D5DCBB1AE5F554E17B1A72A71 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! USBDL : Init HSUSB Ok SIM Lock Status : Locked! Unlocking now ... Error while unlocking, somethig went wrong! Operation Failed Elapsed: 00:00:32 Reconnect Power/Cable! |
