Old 04-21-2008, 22:48   #1 (permalink)
nimanima's Avatar
Member: 144406
Thanks Meter: 21
evry body can give me this frimware???
hi i need full flash for this model: nokia n100 tv
File Type: jpg 3-0-Dual-SIM-TV-Mobile-Phone-HLF-N100-.jpg (61.1 KB, 18 views)
Old 04-22-2008, 02:07   #2 (permalink)
Member: 148515
Thanks Meter: 13,684
hello!
please post here phone's info readed by "read detailed information"
Old 04-22-2008, 11:44   #3 (permalink)
nimanima's Avatar
Member: 144406
Thanks Meter: 21
thanks for your reply this set flashed with wrong flash file but it have 2 cpu i need frimware for cpu1 and it is 6225.
thanks
Old 04-22-2008, 12:06   #4 (permalink)
Member: 148515
hello!
if CPU2 still have original firmware inside- please post it's version
by this version we will try to advice firmware for first MCU
Old 04-22-2008, 12:25   #5 (permalink)
nimanima's Avatar
Member: 144406
Thanks Meter: 21
another cpu is 6223 and i cant conect to that by infinity
Old 04-22-2008, 12:26   #6 (permalink)
Member: 148515
hello!
this can not be true.
you must be using wrong pinout.
please tell detailed how it is "not connect"
post a log
Old 04-22-2008, 13:00   #7 (permalink)
nimanima's Avatar
Member: 144406
Thanks Meter: 21
i cant conect to 6223 cpu with spiderman box also
i solder rx tx on main board and still i cant conect to 6223 cpu
Old 04-22-2008, 19:50   #8 (permalink)
Member: 148515
hello!
procedure of connecting with second MCU is following:
you press & hold power button
first phone will startup (this is first MCU start)
you still hold power button
and only after some time will boot second MCU.
and if you holded power button pressed all the time- you will get connection.
on models which i tested sometimes it took time up to 30seconds to make programm detect second MCU.
so be patient and keep power button pressed
Old 04-25-2008, 11:03   #9 (permalink)
nimanima's Avatar
Member: 144406
Thanks Meter: 21
i flashed it with one frimware and now it on but key problem and ...
after that i could canect to second cpu and read sw ver on it
ver. sw1: LC6223_07A_PCB01_GSM_MT6223_S00.LBN8402_7_12_1_2T0 4M1218_M401A_S.BIN
Old 04-25-2008, 15:55   #10 (permalink)
Member: 148515
hello!
you said you flashed some firmware and now set work
what version did you flash to your phone?
what problem with keys now?
every body can give me this frimware nimanima Infinity-Box 1 05-23-2008 13:07
evry body can give me chines nec n880 flash file? nimanima Infinity-Box 2 11-23-2007 01:43
any body can explain me this errors ?? nassim111 Nokia Base Band 5 ( BB-5 ) 1 02-09-2007 13:36
Any body can give me, manu to flasg BB5 ? I Have to flash 7370 and 6680 Grupo MovilFree Nokia Base Band 5 ( BB-5 ) 2 05-19-2006 16:37
Page generated in 0.28500 seconds with 9 queries
