04-23-2006, 08:41 | #1 (permalink) |
No Life Poster Join Date: Jul 2003 Location: LEBANON
Member: 33690 Status: Offline Thanks Meter: 3,398 | Explain This Just Bought A New Infinity Box With Card Version. I Do Hope You Consider And Check With Your Manufacturer. After Installing Drivers, Could Not Start Software, So I Decided To Open Box And Check, I Was Shocked And Disappointed, Is This The Work Of A Professional Or Some Carpenter. The Sim Card Holder Is Loose And It Was Glued. Have A Nice Day And Comments Are Welcomed. Last edited by ahmedksal; 11-02-2006 at 16:53. |
04-23-2006, 15:35 | #3 (permalink) |
Product Supporter Join Date: Mar 2005 Location: in CPU
Member: 128745 Status: Offline Thanks Meter: 16,936 | @ ahmedksal Thats correct quality is very bad , this is the reason we decided to change our supplyer of Box and cables New cables come from new manufacturer wich will be released soon btw Vygis , SagDD , Thunderstorm use the same manufacturere same box that you just opend Rgds Infinity Box Team |
04-23-2006, 19:40 | #5 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | There is other way: just try to adjust sim card holder contacts. Also it will be not bad to know what kind of problem you have exactly. What errors you see when you try to run software ? |
04-23-2006, 20:00 | #6 (permalink) |
No Life Poster Join Date: Apr 2000 Location: India, China
Member: 44158 Status: Offline Sonork: 100.64344 Thanks Meter: 143 | Hi, We are using/reselling same box since long and no such problems, box works very good, better describe your problem to get the problems solved. BR. |
04-23-2006, 21:07 | #7 (permalink) |
Member: 33690 Status: Offline Thanks Meter: 3,398 | Hello Hi, Most Of The Time, Card Is Not Recognised. I Have To Open Box And Press Card In Order To Use Software. I Dont Think I Will Cope With It Opening The Box Every Now And Then To Fix Card In Its Position. Since It Is Two Days Since I Purchased It, I Will Surely Return It Back To Get A New Box With Better Workmanship. Have A Nice Day. |
You can explain this ???????? Is this mxkey another mirror link | ..::MOBILES::.. | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 01-28-2010 13:38 |
can someone explain this??? | niko21 | ARM9 BASED M62 / M62+ | 9 | 02-01-2005 14:47 |
Griffin Team please explain this | IR-GSM | Griffin | 0 | 10-23-2004 19:24 |
explain this | millpc | Panasonic | 1 | 12-12-2003 18:47 |
Can some1 explain this? | terri_power | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-19-2001 14:31 |
