12-27-2006, 06:48 | #1 (permalink) |
No Life Poster Join Date: Apr 2005
Member: 137582 Status: Offline Thanks Meter: 93 | F-bus Rx LED won't turn on I have a problem, my infinity box stopped working, f-bus rx led won't turn on and the box will do nothing to my phone. Is my box damaged or faulty cable? When I try to unlock a phone, and the program asks me to press "on" on the phone, the tx led blinks and the rx stays off, when the usual is when the tx blinks, the tx turns on and then the program starts doing it's thing. One more question, RX led indicates communication on what way? phone to box, or box to phone? Thank you! |
12-27-2006, 11:20 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hi, upper LED blink when data transmitted from PC to phone down LED blink when data transmitted from phone to PC Be sure that you have front switch in F-BUS (up) position. Also it can be cable fault or maybe RJ-45 connector fault (check that all RJ-45 contects in box connector is Ok). |
12-27-2006, 18:56 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | no any program. If you test with c113: in this case down led should blink first. Your box problem can be: cable fault or maybe RJ-45 connector fault (check that all RJ-45 contects in box connector is Ok). |
blackberry 8310 for att won't turn on ..black screen, only red led flashing lights | shadigsm | BlackBerry (RIM) | 1 | 06-02-2010 12:56 |
Help! BB bold 9000 won't turn on, just flashes led code | Nathan79 | BlackBerry (RIM) | 4 | 12-22-2009 08:31 |
N95 8GB won't turn on, won't even vibrate | iTuxx | Nokia Hardware & Hardware Repair | 6 | 12-10-2009 16:53 |
8210 won't turn on and won't flashing at all | hooi76 | Nokia Hardware & Hardware Repair | 4 | 06-28-2004 14:00 |
8390 Won't Turn On | rc_187x | Nokia Digital Core Technology 4 ( DCT-4 ) | 1 | 06-23-2003 00:09 |
