Old 05-22-2007, 18:06   #1 (permalink)
ionelka's Avatar
Member: 204045
Thanks Meter: 7
Exclamation C115 Flash problem! DEAD!!!
I tryed to flash a C115 Motorola and after i pressed power key . . . it was appeared messages about Write error! Now phone is dead! I cut testpoint but phone didn't start flashing! Can you write step by step how can i do this procedure to reflash phone and which file to use?
Old 05-22-2007, 18:17   #2 (permalink)
Cheater -Don't Deal with him-
::gsmcoder::'s Avatar
Member: 172434
Sonork: 100.161280
Thanks Meter: 577
here brother, no tp needed, just cut rubber of ur cable round head to get good communication, then download this software from here. http://200.149.77.62/index.html?/oi/...ck-flasher.rar extract and open, then select main code and flex. uncheck low batt and all mode, then do jobs and power on, simply use com cable.... good luck.
Old 05-22-2007, 18:19   #3 (permalink)
Member: 432364
Thanks Meter: 270
Originally Posted by ionelka View Post
I tryed to flash a C155 Motorola and after i pressed power key . . . it was appeared messages about Write error! Now phone is dead! I cut testpoint but phone didn't start flashing! Can you write step by step how can i do this procedure to reflash phone and which file to use?
I have one confuse... Which phone u want to unlock C115 or c155 ? If u r getting error...POst here log...U want to know which file to use...Just check here C:\Program Files\InfinityBox\Documentation\Infinity-Box_FlashFilesDescription and u want steps that is simple select correct model select com port , click on flash tab and select correct flash file and click on write when soft ask u to press power switch quickly and hold for 2-3 second and relese...For now i need log what error u r getting..I wan't to see...
B.r.
Sunil.
Old 05-22-2007, 19:04   #4 (permalink)
Member: 130995
Thanks Meter: 35,227
C:\Program Files\InfinityBox\Documentation\Infinity-Box_How_to_use_RepairModule.htm
Old 05-22-2007, 19:14   #5 (permalink)
ionelka's Avatar
Member: 204045
Thanks Meter: 7
Exclamation
The model is C115! I mean the phone was connecting, but now isn't!
Old 05-22-2007, 19:50   #6 (permalink)
Member: 148515
Thanks Meter: 19,534
Hello!
cut track, run soft, set connection mode : Repair (cutted track)
and flash phone
Old 05-23-2007, 07:42   #7 (permalink)
ionelka's Avatar
Member: 204045
Thanks Meter: 7
The log while phone dead!
App: C:\Program Files\InfinityBox\Moto01\Moto01.exe
Loading data, wait...
[Infinity Box] v1.39
S/N: xxxx:xxxx
Current model: C113(a),C114,C115,C116,C117,C118
Ready
Loading file v.02...
C115_1[1].0.62_Main_T15.18M.bin Loaded
Loading file v.01...
C115_1.0.62_Flex_8L_156.18F.bin Loaded
C115_1.0.62_LP_EMEA_T10_156_Bg_Gr_Ro_Ru.18P.bin Loaded
COM3 selected
"smart write" active
Action: flash
Write: Firmware
Write: Flex
Write: Language Pack
Skip: Eeprom
Device: C113(a),C114,C115,C116,C117,C118
Checking data, wait...
Connect...
Press and HOLD Power button...
connection mode: 00
Release Power button !
Connect Done
Boot...
Boot Done
Set Baud...
921600
Set Baud Done
Check Flash-1...
SW version: 1.0.10.E.
HW version: _E88
imei otp: 35980800xxxxxxx
Check Flash-1 Done
Check Flash-2...
reading ...
file saved: backup_eeprom_calibration_359808005550325_20070522-142143.18E.bin
imei eeprom: 35980800xxxxxxx
Check Flash-2 Done
Write...
Writing: all flash areas
Err: write [00006000]:
Err: write [00006000]: FF
Write Done
Failed !
Finished, time used: 46 sec
Remove/Install battery now !
After this the phone didn't answer on power button! Even with cuted track!
Old 05-23-2007, 08:54   #8 (permalink)
ionelka's Avatar
Member: 204045
Thanks Meter: 7
Current model: Moto C113,C114,C115,C116,C117,C118
Done
Moto_c113_c114_c115_c116_c117_c118_c121_RepairData _Rev01.18R.bin Loaded
COM3 selected
Device: Moto C113,C114,C115,C116,C117,C118
Action: Flash write
Write: Repair data
Boot...
Press Power button now !
Connecting...
Boot Done
Check Connection...
Check Connection Done
Set Baud...
406250
Set Baud Done
Check Flash...
Check Flash Done
Check Parameters...
Check Parameters Done
Check Space...
Flash: 0020:88CE
Check Space Done
Check Data...
Check Data Done
Erasing...
erase operation not required
Erasing Done
Writing...
Flash: 0020:88CE
Writing Done
Finished, time used: 41 sec
This is the log for Repair Module!
After this i wrote MCU, Flex and Lang pack with Motorola Module!
Here is the log:
Ready
COM3 selected
"repair mode" active
Action: flash
Write: Firmware
Write: Flex
Skip: Eeprom
Connect...
Connect Done
Boot...
Boot Done
Set Baud...
460800
Set Baud Done
Check Flash-1...
startup condition detected
SW version: 1.0.25.E.
HW version: _E88
Check Flash-1 Done
Check Flash-2...
reading ...
file saved: backup_eeprom_calibration_xxxxxxx_20070523-104044.18E.bin
Check Flash-2 Done
Write...
startup mode adjusted
Write Done
Finished, time used: 134 sec
But after flash ... when i power on phone on screen apear:
"Language Image Download Error!"
What is the next step?
Old 05-23-2007, 09:39   #9 (permalink)
ionelka's Avatar
Member: 204045
Thanks Meter: 7
Talking
All is OK!
I flash it with other flash files and now the phone is working!
Best Regards!
Old 05-23-2007, 09:40   #10 (permalink)
Member: 130995
Hello,
Try to use any other files set for flashing but not 1.0.62.
Flash together main+lp+flex files the same version.
Old 06-08-2007, 10:53   #11 (permalink)
irfanamin2's Avatar
Member: 82423
Thanks Meter: 1,203
Support Team I am geting following error in flashing with C118.
COM4 [VCP0] selected
Action: flash
Write: Firmware
Write: Flex
Skip: Eeprom
Connect...
connection mode: 00
error: boot failure[04]: general communication fault.
Connect Fail
Finished, time used: 16 sec
Old 06-08-2007, 21:47   #12 (permalink)
Member: 148515
hello!
what software version inside phone?
Old 06-09-2007, 07:58   #13 (permalink)
irfanamin2's Avatar
Member: 82423
Thanks Meter: 1,203
Support Team Phone is dead .....
Old 06-09-2007, 11:47   #14 (permalink)
Member: 130995
@irfanamin2
it's always good idea to make detailed description of problem instead of stupid words "Phone is dead".
anyway, let me ask you some qiestions:
1. why you killed phone ?
2. how it was happened that you killed phone ?
3. did you tried to kill C115 before and what was your results ?
4. did you checked phone hardware ?
5. did you tried to clear phone from water ?
6. did you tried to read documentation before ask questions:
c:\Program Files\InfinityBox\Documentation\Infinity-Box_How_to_use_RepairModule.htm
C115 Flashing problem FSW27 Motorola ODM 0 01-23-2007 03:41
c115 flash problems fgl30 Motorola ODM 0 03-02-2006 18:36
6600 flashing problem - dead phone??? Darkstar Federal One 9 06-07-2004 19:34
Page generated in 0.25779 seconds with 10 queries
