09-24-2008, 10:41 | #1 (permalink) |
Freak Poster Join Date: Apr 2008
Member: 742276 Status: Offline Thanks Meter: 9 | F3 not connect when unlocking Is there any F3 version that can/can't be detected by infinity?? |
09-24-2008, 21:49 | #5 (permalink) |
No Life Poster Join Date: Oct 2004 Location: Dominica, West Indies Age: 63
Member: 88701 Status: Offline Thanks Meter: 381 | Hi Make sure the adapter is seated fully. The adapter may not fit snugly. Try applying pressure while connecting. No need to buy clip...I have unlocked all versions of F3 with infinity. If you still have trouble...post an operation log. Good Luck ;smokin |
09-28-2008, 20:42 | #8 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Here is an instruction how to get cable/pinout information: 1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update 2. run Infinity-Box Shell 3. select required model 4. see detailed information about cable/pinout Here is information how to build your own cable: http:///vbb/showthread.php?t=342807 |
Box Not connected When Unlocking | Amarbir | AdvanceUFS | 3 | 04-17-2008 03:30 |
C62 can not connect for unlock | Cobbysyms | FuriousGold | 5 | 10-31-2007 20:25 |
How to modify this patch for not vibra when connect. | ^NaT^ | x4x, x5x Flashpatching | 8 | 12-24-2005 02:24 |
Nokia 3610 show not charging when connect with charger | TechPhone | Nokia Hardware & Hardware Repair | 2 | 01-27-2004 20:29 |
