Old 05-02-2009, 13:45   #1 (permalink)
pallumobile's Avatar
Member: 659890
Thanks Meter: 263
F679 Successful
F679 sucessfuly unlock by the infinity with the help of using s109 serial cable. Here is the logs.
COM2 [Serial0] selected
module v1.03
Device: Samsung-SCH-F679
Checking data, wait...
Action: unlock
Phone should be Switched ON !
Connecting, wait...
Phone detected, wait...
step-1 done
step-2 done
step-3 done
operation finished
Finished, time used: 13 sec
Remove/Install battery now !
The Following 2 Users Say Thank You to pallumobile For This Useful Post:
Old 05-04-2009, 12:24   #2 (permalink)
Parminder Singh's Avatar
Member: 476739
Thanks Meter: 505
please share pinout pin 1...........18
Old 05-05-2009, 21:04   #3 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,296
module v1.03
Action: unlock
Connecting, wait...
step-1 done
step-2 done
step-3 done
operation finished
Thank you very much for test report !
Each test report with attached logs is very important for us
so we can see how is Infinity-Box software works, what is phone hardware configuration (f.e. flash chip type)
and what is possible problems (so we will be able to fix it) and successfully done work.
Old 05-07-2009, 11:18   #4 (permalink)
rk19801's Avatar
Member: 238252
Thanks Meter: 81
F679 pinout plsssssssssss.........
Old 05-07-2009, 11:20   #5 (permalink)
rk19801's Avatar
Member: 238252
Thanks Meter: 81
same as ufs a300 cable or not...plssss help..
Old 05-09-2009, 21:01   #6 (permalink)
Member: 130995
Hello,
Here is an instruction how to get cable/pinout information:
1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update
2. run Infinity-Box Shell
3. select required model
4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information)
Here is an example of information given by Infinity-Box Shell:
Here is information how to build your own cable:
http:///vbb/showthread.php?t=342807
Old 05-10-2009, 10:35   #7 (permalink)
Member: 659890
Thanks Meter: 263
No need of any pinouts. Just use samsung s109 serial cable or fbus cable 100% tested by me.
Old 05-10-2009, 10:47   #8 (permalink)
astana2007's Avatar
Member: 285345
Thanks Meter: 324
nice info boss.carry on nice work.
Old 05-10-2009, 13:31   #9 (permalink)
deepakgarg's Avatar
Member: 220603
Sonork: 100.1624258
Thanks Meter: 1,138
ufs d500 cable via jaf emulator or ustpro d500 cable direct with infinity can b used
The Following 2 Users Say Thank You to deepakgarg For This Useful Post:
Old 05-23-2009, 18:38   #10 (permalink)
Member: 291400
Thanks Meter: 61
f679 pinouts
Pin 5 tx
pin 6 rx
pin 8 gnd
pin 11 gnd
pin 14 pwr
Old 05-24-2009, 01:28   #11 (permalink)
Member: 64244
Thanks Meter: 17
wrong pinout dont fool others post whatever u know surely.
Old 05-24-2009, 08:34   #12 (permalink)
deepakgarg's Avatar
Member: 220603
Sonork: 100.1624258
Thanks Meter: 1,138
keyboard down
5 RX
6 TX
8 GND
14 Vcc
The Following User Says Thank You to deepakgarg For This Useful Post:
Old 06-29-2009, 08:47   #13 (permalink)
Member: 185776
Thanks Meter: 73
Thanks to Deepak Today unlocked samsung f679.Log here
==== log: [6/29/2009 12:08:54 PM] ====
COM3 [VCP2] selected
module v1.03
Action: unlock
Connecting, wait...
step-1 done
step-2 done
step-3 done
operation finished
Finished, time used: 27 sec
The Following User Says Thank You to cellbhai For This Useful Post:
Old 10-09-2009, 11:04   #14 (permalink)
kapilkapoor's Avatar
Member: 113097
Thanks Meter: 364
Samsung-SCH-F679
COM21 [VCP1] selected
module v1.09
Action: unlockPhone should be Switched ON !
Connecting, wait...
step-1 done
step-2 done
step-3 done
operation finished
The Following User Says Thank You to kapilkapoor For This Useful Post:
Old 10-09-2009, 11:21   #15 (permalink)
Member: 113097
Thanks Meter: 364
Samsung-SCH-F679
Samsung-SCH-F679
use samsung n-191 cable
5230 boot display SIM card invalid ATF success with good repair! 20442044 Advance-Box 3 06-09-2015 09:56
Samsung Sch-f679 Pst & Bin File Needed amit_varietymob Samsung CDMA 24 12-05-2011 10:10
E75 Success Unlock!!! jr astigin MXKEY Nokia Flasher and Unlocker (by Alim Hape) 0 03-29-2010 12:19
Page generated in 0.44833 seconds with 9 queries
