09-10-2011, 07:17 | #1 (permalink) |
No Life Poster Join Date: May 2007 Location: uk
Member: 508072 Status: Offline Thanks Meter: 1,621 | facing problem with writting imei in side firmwere from few days module v3.96 Device: _Autodetect MT6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: "repair imei" imei write channel: imei #1 (default imei inside firmware) new imei: 358280015102854 ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:F603:0003 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb otp offset: 00000000 detecting chip #01 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb otp offset: 00000000 detecting chip #02 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb otp offset: 00000000 detecting chip #03 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb otp offset: 00000000 detecting chip #01 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb otp offset: 00000000 it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (05) TCL-ID is absent rom info detection finished rom info ver: 05 sw version: JWT_Z170B_004_PCB01_GPRS_MT6225_S00.LBBMM04_8_32_1 _2T16M0125_M513.BIN project-id: LBBMM01.8.32.2.4T24M0126_M513, 00000000 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: [standard] type (05) TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 standard ffs/eeprom offset confirmed: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF firmware area: 00000000-00DFFFFF detecting startup code area #2... .................................................. .................................................. .................................................. .................................................. .................................................. ...... startup code area #2 is absent sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: 01227E22202200:18E59F00000000 Backup required data Done ====> Patch required data ... detecting ffs/eeprom structure pass 2... ............................. ffs/eeprom: detect std location pass #1... .................................................. ..... ffs/eeprom: detect standard offset pass #1... ffs/eeprom record offset detected ffs/eeprom: detect standard data... ffs/eeprom record size detected ffs/eeprom layout detection complete error: ffs/eeprom detection failed element #2 error: can not detect default imei value Patch required data Fail Finished, time used: 1 min 43 sec Remove/Install battery now ! |
09-10-2011, 08:31 | #2 (permalink) |
Member: 508072 Status: Offline Thanks Meter: 1,621 | after safe format still same COM2 [VCP1] selected module v4.01 Action: reset settings ("format ffs") Model: _Autodetect MT6205-6239 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:F603:0003 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E05 Date: 2006.06.14 Version: 1.0 Version: LBBMM01.8.32.2.4T24M0126_M513 Version: LCSH25_08A_HW ==================== New firmware found (v.4.01, database date: 19.08.2011): LBBMM01.8.32.2.4T24M0126_M513 This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare – Secure Data Logistics or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== detecting structure #2... 1 2 3 5 7 8 9 11 13 done 80 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok building list... done items to clear: 145 warning: wrong packet cs warning: wrong packet cs items cleared: 145 of 145 items remains: 0 Finished, time used: 29 sec COM2 [VCP1] selected module v4.01 Device: _Autodetect MT6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: "repair imei" imei write channel: imei #1 (default imei inside firmware) new imei: 353812000819749 ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:F603:0003 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb otp offset: 00000000 detecting chip #01 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb otp offset: 00000000 detecting chip #02 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb otp offset: 00000000 detecting chip #03 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb otp offset: 00000000 detecting chip #01 in region #00... flash: 01227E22202200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb otp offset: 00000000 it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (05) TCL-ID is absent rom info detection finished rom info ver: 05 sw version: JWT_Z170B_004_PCB01_GPRS_MT6225_S00.LBBMM04_8_32_1 _2T16M0125_M513.BIN project-id: LBBMM01.8.32.2.4T24M0126_M513, 00000000 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: [standard] type (05) TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 flash: 01227E22202200:18E59F00000000 checking area [00000000]: 00080000-00FFFFFF... Can't detect ffs/eeprom area Do you want to use standard ffs/eeprom address: 00E00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard ffs/eeprom address selected by user detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF firmware area: 00000000-00DFFFFF detecting startup code area #2... .................................................. .................................................. .................................................. .................................................. .................................................. ...... startup code area #2 is absent sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... flash: 01227E22202200:18E59F00000000 Backup required data Done ====> Patch required data ... detecting ffs/eeprom structure pass 2... ............................. ffs/eeprom: detect std location pass #1... .................................................. ..... ffs/eeprom: detect standard offset pass #1... ffs/eeprom record offset detected ffs/eeprom: detect standard data... ffs/eeprom record size detected ffs/eeprom layout detection complete error: ffs/eeprom detection failed element #2 error: can not detect default imei value Patch required data Fail Finished, time used: 2 min 15 sec Remove/Install battery now ! Remove/Install battery now ! |
Copy from one 6110 to another | Leif Nielsen | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-10-1999 22:36 |
Netmonitor with FBus???? | ratzfatz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 06-09-1999 17:04 |
