-   Infinity-Box (http://forum.gsmhosting.com/vbb/f296/)
-   -   Failed to unlock fly sl100 (http://forum.gsmhosting.com/vbb/f296/failed-unlock-fly-sl100-638581/)
Mansoor 11-27-2008 15:47
Iam using K800 cable to unlock FlySL100 which has the same pinout but i get
M10 [VCP0] selected
Action: read codes
unlock method: read codes
Model: Fly-SL100
Checking data, wait...
9600 autodetect
error: boot phase#2/1 failed
Can't initialize test mode !
Possible reasons:
1. communication fault, repeat required operation
2. eeprom/ffs serious damaged, use repair eeprom/ffs files or use other unlock/format method
error: operation failed !
Finished, time used: 27 sec
Remove/Install battery now !
What is the problem and if it is cable problem were can i get the correct pinout for the cable
InfinitySupport 11-27-2008 19:55
Hello,
It looks like it's pinout problem, you need to double check SL100 pinout in "Shell".
Waiting for results.
Page generated in 0.10215 seconds with 5 queries
