10-17-2008, 20:01 | #1 (permalink) |
Super Moderator Join Date: Jul 2008 Location: Villa del rosario/Nsd Colombia
Member: 813309 Status: Offline Thanks Meter: 1,912 | FAILURE UNLOCK ALCATEL S520A I had Q EARNING DEAD WITH POLAR BOX HERE THE LOG ==== log: [16/10/2008 13:33:19] ==== COM19 [VCP0] selected module v2.36 Device: Alcatel-OT-S520X, S520A Checking data, wait... advanced flash detection enabled Action: write NOR flash "smart write" active "format ffs" active write: Firmware skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6225:8A03:8A00]... CPU: MT6225 chip: 0001:2703:A00C boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 01227E22442200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x008000 007Ex020000 0004x008000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud... 460800 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area (code #1) is Ok security area (code #1) backup saved: C:\Archivos de programa\InfinityBox\MModule\backup_security\id.A5 72578A.[JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V34.BIN_B8A8FFD4].rpl identification#1 detection finished device-id: A572578A identification#1 protocol ver: 05 ver. sw1: JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V34.BIN ver. sw2: MAUI.06B.W07.28.SP1.V34, 2B005747 ffs offset/size: 00C00000/00400000 detect device identification#2... detection phase #1... detect device identification#2 finished sim-lock status: enabled Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... original imei: 01143900053292 Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... security area (code #1) calculation... done file saved: C:\Archivos de programa\InfinityBox\MModule\backup_security\syste m_log_A572578A_JRD25_06B_PCB01_GPRS_MT6225_S00.MAU I_06B_W07_28_SP1_V34.BIN_B8A8FFD4_20081016-133359.B0X.bin Area: Firmware flash: 01227E22442200:18E59F00000000 Write: Firmware detect device identification#2... detection phase #1... detect device identification#2 finished security area (code #3, part #2) calculation... customization: CD44GD00 done flash: 01227E22442200:18E59F00000000 flash: 01227E22442200:18E59F00000000 Write: security area (code #3, part #2) error: wrong answer: C4 error: flash write error: 00BFC000:00002000 error: wrong answer: C7 error: flash write error: 00BFC000:00002000 error: wrong answer: 3B error: flash write error: 00BFC000:00002000 error: wrong answer: 3B error: flash write error: 00BFC000:00002000 error: wrong answer: 3B error: flash write error: 00BFC000:00002000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 0000000000 error: can't write required area security area (code #3, part #2) calculation failed Write Done Finalization... formatting... error: wrong answer: 3B error: wrong answer: 3B : wrong answer after chip id request error: wrong answer: 3B error: wrong answer: 3B error: no any expected answer: wrong answer after chip cfi request error: wrong answer: 3B error: no any expected answer: wrong answer after chip id request Finalization Fail file saved: C:\Archivos de programa\InfinityBox\MModule\backup_security\syste m_log_A572578A_JRD25_06B_PCB01_GPRS_MT6225_S00.MAU I_06B_W07_28_SP1_V34.BIN_B8A8FFD4_20081016-134236.B0X.bin Finished, time used: 552 sec Remove/Install battery now |
10-17-2008, 20:28 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Yes, I see it's urgent so here is my advice: Any urgent job should be done with 100% (completely charged battery, in other case you can see write problems at end of process. So try to interrupt message writing and charge battery completely. Then flash phone again. if problem still exist with completely chrged battery you must open phone and check it's hardware (f.e. reball flash chip). Thank you for your understanding. Hope next time you will be more careful and you will wait answer with patience instead of spam forum with useless posts. |
10-17-2008, 21:28 | #6 (permalink) | |
Insane Poster Join Date: Feb 2003 Age: 42
Member: 20666 Status: Offline Thanks Meter: 3 | Quote:
You can repair this with Polar Box flashing again Tested by me Regards | |
10-18-2008, 22:03 | #9 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @Philips Just for your information: here is Infinity-Box support forum so please, let\'s talk here about Infinity-Box. As about phones repair: in compare with other tools you are able to repair EMPTY-BOARD Alcatel phones (phones with completely empty or erased flash chip) with Infinity-Box. |
Alcatel of 206 dead with polar [ANSWERED] | kopsa2005 | PolarBox 3 | 11 | 08-01-2014 11:35 |
Polar team support, alcatel died after release with polar box ..... [ANSWERED] | boliargsm | PolarBox 3 | 6 | 02-06-2010 08:06 |
GB 102 Dead with Polar BOX? [SOLVED] | Tetouan Gsm | PolarBox 3 | 14 | 01-19-2010 13:10 |
Alcatel s920 successfully unlocked with polar box | dasuza | PolarBox 3 | 3 | 10-28-2008 21:16 |
